Thread: Prevent objects from inheriting system color
    2018-06
    18
    Default Prevent objects from inheriting system color
    When I create an object family that has a pipe connector, the object always changes color to match the color assigned to the system I connect it to. But I don't want it to do this. I want it to keep the colors I gave it in the family editor. How do I go about making this happen?
    2017-07
    Virginia Beach, VA
    9
    Default Re: Prevent objects from inheriting system color
    I would look into making the family type something other than a Pipe Fitting.
  1. New Robot models inheriting old data when transferring from Revit
    By leon.sullivan181291 in forum Robot Structural Analysis
    Last Post: 2011-09-08, 01:25 PM
  2. Pin Position shold lock pinned objects to prevent flexing when adjoining objects change
    Last Post: 2009-03-29, 03:58 PM
  3. Column Inheriting Material of Wall
    By psteel in forum Revit Architecture - General
    Last Post: 2006-05-22, 04:46 PM
  4. Column Inheriting Material
    Last Post: 2006-05-22, 12:09 PM
  5. Inheriting layers
    By robert.1.hall72202 in forum AutoCAD Customization
    Last Post: 2005-06-03, 09:07 PM
