Thread: Help with Image layer lisp
    topomav
    Guest
    Default Help with Image layer lisp
    Hi, I am using this code to move all images from model and paper space to the layer Image.
    I want to update this code to move all images from model space to layer Image_Model and all images from paper space to layer Image _Lay.
    Can any one help me?
    HTML Code:
    (vl-load-com)
    (defun c:LinkLayerImage (/ *error* acDoc layerName oLayer ss)
      (defun *error* (msg)
        (if ss
          (vla-delete ss)
        (if acDoc
          (progn
            (vla-endundomark acDoc)
            (vla-regen acDoc acallviewports)
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
      (if (ssget "_X" '((0 . "IMAGE") (8 . "~Image")))
        (progn
          (vla-startundomark
          ;; get or create layer
          (setq oLayer
                 (vla-add (vla-get-layers acDoc) (setq layerName "Image"))
          ;; set image layer
          (vlax-for x (setq ss (vla-get-activeselectionset acDoc))
            (vla-put-layer x layerName)
          ;(setvar 'clayer "Line1")
    ;(alert "image done")
      (*error* nil)
    Tallahassee, FL USA
    3,667
    Default Re: Help with Image layer lisp
    Add a filter to determine the Layer name based on if group code 67 equals 1. https://help.autodesk.com/view/ACD/2...3-7E60B22BB5BD
    Group code 67 - Absent or zero indicates entity is in model space. 1 indicates entity is in paper space (optional).
    topomav
    Guest
    Hi, Tom Beauford. Can you help with the code because I am not good in lisp.
    2010-06
    962
    I did not test the following routine so please try it and let me know and be sure to have your layers unlocked in prior otherwise if any on locked layer then it won't be moved to the target layer name and besides that, if you don't have the two target layers then the program will add them with default values like White color ..... etc.
    (vl-load-com)
    (defun c:LinkLayerImage (/ *error* acDoc s i n e mod lay)
        (if acDoc
          (progn
                                            ; <esc> or (quit)
      (if (setq s (ssget "_X" '((0 . "IMAGE") (8 . "~Image"))))
        (progn
          (vla-startundomark
          (vla-add (vla-get-layers acDoc) (setq mod "Image_Model"))
          (vla-add (vla-get-layers acDoc) (setq lay "Image_Lay"))
          (repeat (setq i (sslength s))
            (setq i (1- i)
                  n (ssname s i)
                  e (entget n)
            (entmod (subst (cons 8
                                 (if (= (cdr (assoc 67 e)) 1)
                                   mod
                                   lay
                           (assoc 8 e)
                           e
      (*error* nil)
    topomav
    Guest
    Thank you Tharwat
    2010-06
    962
    Quote Originally Posted by Razor View Post
    Thank you Tharwat
    You're welcome anytime.
  1. Combine query lisp with layer draw order lisp?
    By wayne.murphy704398 in forum AutoLISP
    Last Post: 2020-11-06, 03:08 AM
  2. 2015: Insert image, unload image, image border stays around
    By invaderkyle in forum AutoCAD General
    Last Post: 2015-04-10, 03:23 PM
  3. LISP to create layer, hatch and set layer back to original.
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2013-12-11, 07:22 PM
  4. Replies: 13
    Last Post: 2011-06-28, 03:31 PM
  5. layer control: lisp vs layer manager
    By gseals in forum AutoCAD Customization
    Last Post: 2004-10-08, 02:36 PM
