Re: 4k Compatibility Improvements
Summary: Use display resolution for drafting space and display scale for user interface and panels
Description: Hello!
I've been drafting on a 4k screen for quite a while now, working with point clouds, and all I can get out of it so far is either 4k resolution with 100% scaling (so still pixel for pixel the same height text but really small with respect to screen size) or antialiased 1080p resolution. I've found that the entire program revolves around the Display Scale, so even if I set the resolution to 4k and set the Display Scale to 200% the screen still renders at 1080p. I could go into all the display settings and mess with every font etc until it suits a 4k environment, but if they were able to restrict the scaling to the UI and maintain screen resolution inside the drawing window, life would be peachy.
Thanks!
Product and Feature: AutoCAD - User Interface
Submitted By: sebastien795355 on 04/20/2022
- You may not post replies
- You may not edit your posts
Forum Rules
