Results 1 to 8 of 8
Thread: missing data table
    2004-06
    Slidell, Louisiana
    972
    Default missing data table
    I am dragging and dropping a shp file in a dwg. the points show up but I
    can not get the data table to display. Is there a setting somewhere to bring it up?
    It also does not show up when I use the data connect option to bring in the shape.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: missing data table
    Are you certain the SHP file contains object data?
    What are the settings you are using for DATA if you use the MAPIMPORT command?
    2004-06
    Slidell, Louisiana
    972
    Yes, it has data in it. I can drag and drop it on another computer running the same software.
    2002-01
    jUSt Here (a lot)
    9,100
    Quote Originally Posted by rmk View Post
    Okay, the first question was answered.
    2004-06
    Slidell, Louisiana
    972
    we tried just dragging and dropping the shp file into the drawing. cannot get the layer to display the data table in the task pane.
    we also tried connecting the shp file via the data connection. the layer is there, the points come in as map features, but when you
    select the layer, the data table icon isn't selectable (grayed out). I've tried typing MapDataTable at the command line, but no table is displayed.
    it works just fine on 2 other machines in the office. I'm wondering if we need to run a repair software session to see if that will fix the problem.
    2002-01
    jUSt Here (a lot)
    9,100
    Does the Property palette list any data for the selected object?
    Hopefully, a software repair resolves the issue without causing too long of a delay.
    2004-06
    Slidell, Louisiana
    972
    Yes, if you select the map feature on screen and go to properties palette it does show the data.
    Is it possible the dialog box is off screen? I don't remember the steps to bring it back into view.
    2002-01
    jUSt Here (a lot)
    9,100
    If it is a normal dialog box, the keyboard shortcut is "Alt" + "Spacebar"
  1. 2019: Created a data linked table, can I now have certain attributes pull from that table?
    By dollada06738771 in forum Productstream - General
    Last Post: 2018-06-19, 08:18 PM
  2. Table last data line missing
    By stephane.laferriere in forum AutoCAD Tables
    Last Post: 2009-02-24, 06:33 PM
  3. Where's the table/table styles data
    By jorozco in forum AutoCAD Tables
    Last Post: 2006-11-03, 06:19 AM
  4. How to Create Access table data to AutoCAD VBa Combo box data
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-06-20, 08:22 PM
  5. Linking AutoCAD Object Data Table to Access table
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-05-02, 02:54 PM
