Thread: Losing Linked DWG
    All AUGI, all the time dsw98's Avatar
    2005-02
    Salt Lake City, Ut
    621
    Cool Losing Linked DWG
    For some reason I'm losing linked DWG's from my project. The file locations haven't changed. I'll bring the file in, work on it. Then close the project for the day, then the next day it's not there. Yet it shows up in the Manage Link tab. I've tried reloading it, but that doesn't work. The only thing I can do is remove it and link it again. Is there a step I'm unaware of that I should be doing to keep the DWG's permanently linked?
    in the upper right corner
    3,507
    Default Re: Losing Linked DWG
    Quote Originally Posted by dsw98 View Post
    So it sounds like you're not "losing it" because you mention it's in the manage link tab, so you still have it but not seeing it?
    Is it possibly on a workset being turned off, or maybe a design option? or simply being turned off through VG or in a view template setting?
    2005-02
    Salt Lake City, Ut
    621
    Thanks for the response. It's a no to all of the above. I've checked all those things you mentioned. Worksets aren't enabled and there are no design options. It's a real head scratcher.
  1. 2014: Revit STC issue - Tags of linked elements losing host
    By superglenn77 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2017-08-30, 04:22 AM
  2. 2014: Linked views losing their link in central model
    By ward536978 in forum Revit Architecture - General
    Last Post: 2017-07-17, 12:27 PM
  3. Tagging Linked Components - Losing Hosts
    By cstarr in forum Revit Architecture - General
    Last Post: 2012-02-15, 05:26 AM
  4. Linked files losing view settings and views of file
    By DoTheBIM in forum Revit Architecture - General
    Last Post: 2006-07-18, 12:29 PM
