We want yes/no parameter for walls that when checked will display text in a wall tag. Is this doable? I am familiar with families but not with formulas.
Thanks in advance
Thanks in advance
In your tag family, select the label you want to be able to turn on and off and then select the small grey square to the right of the visibility check box in properties and associate a parameter to it.Attachment 109101
Thanks marmiketin, the parameter we want to associate is a visibility (Yes/No) parameter and it does not work
That is exactly what I am showing in the picture. Go into your tag family, select the label you want to be able to turn on/off, then in properties click the grey box next to visible and set a yes/no parameter for it.
You will also have to have a parameter for the text the label contains, this would be either an existing shared parameter, or a new one. Then load into the project and make sure the shared parameter is associated with a project parameter.
Go to Manage TAB --> Project Parameters --> Add --> Shared Parameter --> Select the one you assigned in the family --> associate to the correct category
