Thread: Eror: Not all intersecting references ... could be used to intersect the surface
    2006-12
    11
    Default Eror: Not all intersecting references ... could be used to intersect the surface
    Hi All,
    I have searched multiple posts in different Revit forums posts but I could not find a clear resolution to this problem. It seems this is a long-lasting item that Revit does not seem to work well with.
    I have a conceptual mass and I pushed/pulled some of the edges to create a faceted surface. Then I added horizontal and vertical Reference Planes with defined names. Note that the divided surface UV layout is set to “None”.
    Then I use the “Intersect” feature with the Divided Surface to get my custom UV layout. But no matter what I do, I get this error [Not all intersecting references (levels, reference planes or lines) could be used to intersect the surface]. Then when I apply a simple curtain panel pattern base on the divided surface, some panels do not get placed.
    I will appreciate any help or pointers.
    2006-12
    11
    Default Re: Eror: Not all intersecting references ... could be used to intersect the surface
    I also forgot to mention that when I apply the curtain panel pattern base, there are some gaps. And some panels get created even though there is no intersecting plane!
    Thank you
  1. Replies: 15
    Last Post: 2012-07-20, 10:03 PM
  2. EROR IN IMPORT HATCH
    By thinhphamkts in forum Revit Architecture - General
    Last Post: 2010-07-22, 12:39 AM
  3. Eror in Loading Structure Family
    Last Post: 2010-05-24, 03:25 PM
  4. Intersect a solid with a surface?
    By madlyons in forum AutoCAD 3D (2006 or below)
    Last Post: 2008-01-04, 01:44 PM
  5. Replies: 3
    Last Post: 2007-06-05, 06:29 AM
