InsertBlock Method (ActiveX)
Inserts a drawing file or a named block that has been defined in the current drawing.
Supported platforms: Windows only
Signature
VBA:
RetVal = object.InsertBlock(InsertionPoint, Name [, Xscale [, Yscale [, ZScale [, Rotation [, Password]]]]])object
Type: Block, ModelSpace, PaperSpace
The objects this method applies to.
InsertionPoint
Access: Input-only
Type: Variant (three-element array of doubles)
The 3D WCS coordinates specifying the location in the drawing to insert the block.
Name
Access: Input-only
Type: String
The name of the AutoCAD drawing file or the name of the block to insert. If it is a file name, include the .dwg extension and any path information necessary for AutoCAD to find the file.
Xscale
Access: Input-only; optional
Type: Double
The default equals 1.0. Must be a positive number.
Yscale
Type: Double
Zscale
Type: Double
Rotation
Type: Double
The default equals 0.0 radians.
Password
Type: Variant
The password that was applied to the drawing file when it was saved.
Return Value (RetVal)
Type: BlockReference
The placed block as a Block Reference object.
Remarks
Inserting a block into another block will create nested blocks.
Attempting to call the InsertBlock method with an uninitialized Name parameter results in unexpected behavior.
Examples
VBA:
Sub Example_InsertBlock()
' This example creates a block containing a circle.
' It then inserts the block.
' Create the block
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
' Add a circle to the block
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 0: center(1) = 0: center(2) = 0
radius = 1
Set circleObj = blockObj.AddCircle(center, radius)
' Insert the block
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
ZoomAll
End SubVisual LISP:
(vl-load-com)
(defun c:Example_InsertBlock()
;; This example creates a block containing a circle.
;; It then inserts the block.
(setq acadObj (vlax-get-acad-object))
(setq doc (vla-get-ActiveDocument acadObj))
;; Create the block
(setq insertionPnt (vlax-3d-point 0 0 0))
(setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "CircleBlock"))
;; Add a circle to the block
(setq center (vlax-3d-point 0 0 0)
radius 1)
(setq circleObj (vla-AddCircle blockObj center radius))
;; Insert the block
(setq insertionPnt (vlax-3d-point 2 2 0))
(setq modelSpace (vla-get-ModelSpace doc))
(setq blockRefObj (vla-InsertBlock modelSpace insertionPnt "CircleBlock" 1 1 1 0))
(vla-ZoomAll acadObj)
