Results 1 to 7 of 7
Thread: Ilogic Boiler Panel wall
    2022-05
    Default Ilogic Boiler Panel wall
    Hello
    I am trying to build an ilogic the can parametric control a assembly of a wallpanel for a boiler. I am using a Skeletal modelling teknik to build the model and sync/update that into to the assembly.
    But the catch is following:
    1. If the Cladding is on , then the Slit Cutout shall be in every middle fines and if the Cladding is covering the Slit Cutout then the Slit Cutout has to cut through the cladding also.
    2. If the Cladding is off, then the Slit Cutout shall be in every second middle fin if the Cladding is covering the Slit Cutout then the Slit Cutout has to cut through the cladding also.
    Any suggesition?....
    5,980
    Default Re: Ilogic Boiler Panel wall
    I moved this to the Inventor forum for you.
    If this is for iLogic, then you should show your code. Put the code in code tags by going to the Advanced editor and selecting the </> button.
    If this is just a parametric model, then post your ipt file, so others can help you.
    2022-05
    How do edit my post ? i can't find the place.
    2022-05
    Hello
    The code:
    'Parameter panel from skelet model
    Parameter("test_skeletmodel:1", "Totalheight") = Panelheight
    Parameter("test_skeletmodel:1", "pitch") = Pitch
    Parameter("test_skeletmodel:1", "tubes") = Tubes
    Parameter("test_skeletmodel:1", "Vertical_section")=Verticalsection
    Parameter("test_skeletmodel:1", "Tube_Bend_radius")=panelbendradius
    Parameter("test_skeletmodel:1", "deduction")=Deduction
    'Parameter fin slit from skeletmodel
    Parameter("test_skeletmodel:1", "pitch_left_side") = Fin_width_left
    Parameter("test_skeletmodel:1", "pitch_right_side") = Fin_width_left
    'Parameter tube material and certifikat
    iProperties.MaterialOfComponent("test_tube:1") = Tube_material
    'Parameter tube Certifikat
    MultiValue.SetListInComponent("test_tube:1", "Cert", "EN10204-2.2", "EN10204-3.1", "EN10204-3.2")
    Parameter("test_tube:1", "Cert") = Tube_Material_Certifikat
    'Parameter tube dimension data
    Parameter("test_skeletmodel:1", "Tubediameter") = pipediameter
    Parameter("test_skeletmodel:1", "Tube_wall_thickness") = pipethickness
    Parameter("test_skeletmodel:1", "Pipechamfer") = Tube_end_chamfer
    'Chanfer on tubes yes or no
    If  Tube_end_chamfer = False
    	Feature.IsActive("test_skeletmodel:1", "Topchamfer_pipe") = False
    	Feature.IsActive("test_skeletmodel:1", "bottomchamfer_pipe") = False
    Else If Tube_end_chamfer = True
    	Feature.IsActive("test_skeletmodel:1", "Topchamfer_pipe") = True
    	Feature.IsActive("test_skeletmodel:1", "bottomchamfer_pipe") = True
    End If
    'Parameter fines on/off
    Parameter("test_skeletmodel:1", "Fin_thickness") = finthickness
    Parameter("test_skeletmodel:1", "fin_cutout") = fincutoutlength
    'Parameter("Test_fin:1", "Fin_slit_YesNO") = Fin_slit_end
    'If  Fin_slit_end = False
        'Feature.IsActive("Pattern_finslit_bottom") = False
        'Feature.IsActive("Pattern_finslit_top") = False
    	'Feature.IsActive("Finslit_Cutout_bottom") = False
    	'Feature.IsActive("Finslit_Cutout_top") = False
    'Else If Fin_slit_end = True
    	'Feature.IsActive("Pattern_finslit_bottom") = True
        'Feature.IsActive("Pattern_finslit_top") = True
    	'Feature.IsActive("Finslit_Cutout_bottom") = True
    	'Feature.IsActive("Finslit_Cutout_top") = True
    'End If
    'Parameter fines configuration inconel yes/no
    'If Internal_Cladding = True Or External_Cladding = True
    	'Parameter("Fin_slit_numbers") = Tubes - 1
    	'Parameter("Fin_Slit_pitch") = Pitch
    	'Parameter("Fin_slit_numbers") = Tubes-1
    'Else If Internal_Cladding = False Or External_Cladding = False
    	'Parameter("Fin_slit_numbers") = Round((Tubes - 1) / 2)
    	'Parameter("Fin_Slit_pitch") = Pitch * 2
    'End If
    'fin left side configuration
    If Leftside_fin_configuration = "None" Then
    Feature.IsActive("test_skeletmodel:1", "Chamfer1left") = False
    Feature.IsActive("test_skeletmodel:1", "Chamfer2left") = False
    Feature.IsActive("test_skeletmodel:1", "Chamfer3left") = False
    Else If Leftside_fin_configuration = "Chamfer1"
    	Feature.IsActive("test_skeletmodel:1", "Chamfer1left") = True
    Else If Leftside_fin_configuration = "Chamfer2"
    	Feature.IsActive("test_skeletmodel:1", "Chamfer2left") = True
    Else If Leftside_fin_configuration = "Chamfer3"
    	Feature.IsActive("test_skeletmodel:1", "Chamfer3left") = True
    End If
    'fin equal check
    'If Equal_end_fins = True
    	'Then Leftside_fin_configuration = Rightside_fin_configuration And Rightside_fin_configuration = Leftside_fin_configuration
    'Else If Equal_end_fins = False
    	'Then Leftside_fin_configuration = Leftside_fin_configuration And Rightside_fin_configuration = Rightside_fin_configuration
    'End If
    'fin right_side configuration
    If Rightside_fin_configuration = "None" Then
        Feature.IsActive("test_skeletmodel:1", "Chamfer1right") = False
    	Feature.IsActive("test_skeletmodel:1", "Chamfer2right") = False
    	Feature.IsActive("test_skeletmodel:1", "Chamfer3right") = False
    Else If Rightside_fin_configuration = "Chamfer1"
    	Feature.IsActive("test_skeletmodel:1", "Chamfer1right") = True
    Else If Rightside_fin_configuration = "Chamfer2"
    	Feature.IsActive("test_skeletmodel:1", "Chamfer2right") = True
    Else If Rightside_fin_configuration = "Chamfer3"
    	Feature.IsActive("test_skeletmodel:1", "Chamfer3right") = True
    End If
    'Parameter Cladding
    Parameter("Test_skeletmodel:1", "cladding_cutout") = Free_lenght_cladding
    'Cladding on/off
    'Inner Cladding
    	    Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner:pattern") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner_pattern") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_inner") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_inner") = False
    	Else If Internal_Cladding = True
    		Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner:pattern") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner_pattern") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_inner") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_inner") = True
    End If
    'Outer Cladding
    If External_Cladding = False
    	    Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer_pattern") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer_pattern") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_outer") = False
    	Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_outer") = False
    	Else If External_Cladding = True
    		Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer_pattern") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer_pattern") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_outer") = True
    	Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_outer") = True
    End If
    'Check if tubes are even or odd
    'If Tubes Mod 2 = 0  AndAlso Internal_Cladding = True
    '	Component.IsActive("Pattern_fin_slit_odd") = False
    '	Component.IsActive("Pattern_fin_odd") = False
    '	Component.IsActive("Pattern_fin_slit_even") = True
    '	Component.IsActive("Pattern_fin_even") = False
    'Else If Tubes Mod 2 = 1 And Internal_Cladding = False
    '	Component.IsActive("Pattern_fin_slit_odd") = True
    '	Component.IsActive("Pattern_fin_slit_even") = False
    '	Component.IsActive("Pattern_fin_even") = True
    'End If
    'Opdatering af skeleton
    iLogicVb.RunRule("test_skeletmodel:1", "update")
    iLogicVb.UpdateWhenDone = True
    Code attached and and models. Ilogic placed in assembly.
    5,980
    Quote Originally Posted by elfert View Post
    I don't think you can edit it once someone has replied to it.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,820
    There should be an "Edit Post" button at the bottom right of your post. There should also be a Reply, Reply With Quote, and a Multi-Quote button with no text. The Multi-Quote button works like a check box allowing one to quote multiple posts within one reply. The Reply to Thread button is used after the Multi-Quote button is used since Multi-Quote does not work with the Quick Reply feature.
    5,980
    Oops, I was thinking of the wrong forum.
  1. 2014: Electrical Panel Schedule (1-Phase Panel to a 3-Phase Panel)
    By Binu Mathew in forum Revit MEP - General
    Last Post: 2015-03-26, 02:56 PM
  2. Who uses iLogic and what do you think of it
    By pjohnson.137155 in forum Inventor - General
    Last Post: 2012-06-15, 11:39 PM
  3. 30kw boiler family
    By jschraud228486 in forum Revit MEP - Families
    Last Post: 2011-06-21, 08:47 PM
  4. Better access to curtain wall panel widths in panel families
    Last Post: 2009-11-03, 03:22 PM
  5. Boiler room
    By kszyho in forum AutoCAD Gallery
    Last Post: 2009-01-24, 08:19 PM
