Results 1 to 7 of 7
Thread: Routine for creating Arc by Tangent-Tangent-Radius
    2013-02
    49
    Default Routine for creating Arc by Tangent-Tangent-Radius
    Good day!
    Is there's a routine for creating Arc by Tangent-Tangent-Radius?
    Thank you in advance.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Routine for creating Arc by Tangent-Tangent-Radius
    With TRIMMODE (System Variable) set to 0 (Off) the FILLET command is all you need.
    You can add a macro to toggle TRIMMODE On/Off
    Command Name Fillet Trim
    Description Toggle TrimMode On/Off
    Macro ^P(ai_onoff "trimmode") ^P
    Image RCDATA_16_FILLET
    After adding the command macro to a Ribbon Panel set the Display name to: $(if,$(and,1,$(getvar,trimmode)),!.)Trim Fillets
    2003-07
    561
    From the very limited testing trimmode really helps but it always does a inside arc, I tried to do a outside arc and had to use Circle TTR to get correct result.
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by BIG-AL View Post
    That what I use your arcfill.lsp for: https://www.cadtutor.net/forum/topic...comment-500044
    2003-07
    561
    That link was based on 2 lines not 2 arcs so failed for me.
    2015-10
    Belgrade, Serbia, Europe
    564
    This can be very handy, though little slow...
    HTH., M.R.
    2001-03
    Tallahassee, FL USA
    3,667
    Sorry been a while since I looked at it, I must have modified it.
    Seems to work, give it a try.
    ;|draws an arc between 2 lines but does not erase
       by Alan H Aug 2015  shared by BIGAL
       http://www.cadtutor.net/forum/showthread.php?96989-Connecting-lines-with-an-arc&p=662481&viewfull=1#post662481
       Macro: ^P(or C:arcfill (load "arcfill.lsp"));arcfill
       Command line: (load "arcfill.lsp") arcfill
    (defun c:arcfill ( / *Error* eend oldsnap pt1 pt2 pt3 pt4 pt5 ent1 ent2 obj1 obj2 obj3 obj4)
     (defun *Error* (msg) ; embedded defun
       (setvar 'osmode oldsnap)
       (setvar "qaflags" 0)
       (if (/= s "Function cancelled")
         (princ (strcat "\nError: " msg))
       (princ)
    ;  (alert "Arc drawn clockwise from 1st line to 2nd line.")
      (setq oldsnap (getvar 'osmode)
            eend (cdar(entget(entlast)))
      (setvar 'Osmode 512)
      (setq pt1 (getpoint "\npick 1st line")
            ent1 (ssname (ssget pt1) 0)
            Ent1Typ (cdr(assoc 0 (cdr(entget ent1))))
            pt2 (getpoint "\npick 2nd line")
            ent2 (ssname (ssget pt2) 0)
            Ent2Typ (cdr(assoc 0 (cdr(entget ent2))))
            rad (getdist "\nEnter radius")
            obj1 (vlax-ename->vla-object ent1)
            obj2 (vlax-ename->vla-object ent2)
    ;  (if(or(eq Ent1Typ "POLYLINE")(eq En1Typ "LWPOLYLINE"))
      (if(eq En1Typ "LWPOLYLINE")
        (progn
          (princ "\nGot here")
          (vla-copy obj1)
    ;      (setq ss (ssadd) ss (ssadd (entlast)))
    ;      (sssetfirst nil ss)
          (setvar "qaflags" 128)
    ;      (command-s "EXPLODE" ss)
    ;      (vl-cmdf "explode")	; Explode the copied object.
          (vl-cmdf "explode" (entlast))	; Explode the copied object.
    ;      (setq ent1 (ssname (ssget pt1 '((0 . "LINE,ARC"))) 0)
          (setq ent1 (ssname (ssget pt1) 0)
    ;  (if(or(eq Ent2Typ "POLYLINE")(eq En2Typ "LWPOLYLINE"))
      (if(eq En2Typ "LWPOLYLINE")
        (progn
          (vla-copy obj2)
    ;      (setq ent2 (ssname (ssget pt2 '((0 . "LINE,ARC"))) 0)
          (setq ent2 (ssname (ssget pt2) 0)
    ;  (Princ "Ent1Typ set to ")(Princ Ent1Typ)
    ;  (Princ "\nEnt2Typ set to ")(Princ Ent2Typ)
    ;  (Princ "\nRadius set to ")(Princ rad)
      (command "offset" rad ent1 pt2 "")
      (setq obj3 (vlax-ename->vla-object (entlast)))
      (command "offset" rad ent2 pt1 "")
      (setq obj4 (vlax-ename->vla-object (entlast))
            pt5 (vlax-invoke obj3 'intersectWith obj4 acExtendThisEntity) ; Arc Center
            pt3 (vlax-curve-getClosestPointto obj2 pt5)
            pt4 (vlax-curve-getClosestPointto obj1 pt5)
      (vla-delete obj3)
      (vla-delete obj4)
      (command "arc" "C" pt5 pt3 pt4)
    ;(c:arcfill)l
  1. Arc Tangent to Line or Arc with Osnap
    Last Post: 2014-11-13, 12:07 PM
  2. 2015: Sketch - Tangent arc to another arc.
    By yn677298 in forum Inventor - General
    Last Post: 2014-09-24, 03:45 PM
  3. 2014: constructing an arc tangent to an arc and a line
    By aellsworth in forum AutoCAD Tips & Tricks
    Last Post: 2013-12-19, 08:40 PM
  4. Arcs by P.C., arc length, Radius, Tangent bearing, Delta
    By justinxxvii in forum AutoCAD General
    Last Post: 2006-04-29, 10:32 PM
  5. Any way to draw an arc by tangent, tangent, radius?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2005-09-01, 01:49 PM
