Results 1 to 7 of 7
Thread: paper space issues
    2018-03
    40
    Default paper space issues
    Hi All
    I am trying to sort out a problem that really isn't a problem.
    I use project navigator to place view ports in my paper space,
    In the model tab the lines and text are neat and sharp on the screen, but when I change to the layout tab (paper space) the lines and text are blurry and thick, it looks terrible.
    However if I print the drawing to pdf it looks the same as the model space drawing, crisp and sharp. If I print the pdf to paper it looks crisp and sharp, If I print direct from paper space to the printer it looks crisp and sharp.
    It is only while the drawing is displayed on the monitor that the lines are thick and blurry. This would tend to point me to a problem with the monitor, or the graphics card or the computer.
    However if I open the same drawing with AutoCAD 2014 on the same computer and monitor, the drawing is crisp and sharp in the model tab and the layout tab (paper space) and of course however I print it, it looks perfect.
    does any know if there is a setting that adjusts how the drawings are displayed in paper space, As I said it really isn't a problem as the resulting pdf or paper print outs are perfect its only my OCD and the fact that I try to proof the drawings on the screen before I print them out that is giving me a headache.
    any help appreciated
    thanks in advance.
    John
    6,006
    Default Re: paper space issues
    Try this: In the page setup manager, uncheck "Display Plot Styles" in the upper right corner.
    2018-03
    40
    Hi Ed
    thanks for the reply
    I tried this and it turned off all the plot styles and the paper space took on the same colours as the model space, however the blurry ness (if thats a word) remained
    Thanks any way it was worth a try
    6,006
    Is this something that just started happening? Just on your pc? Any other info you can give that would help troubleshoot?
    2018-03
    40
    Hi All
    thanks for the replies sorry for taking so long to get back but we are so busy i have just learned to put up with it,
    just to answer some questions
    Its just on this PC the drawing is fine on my laptop although much smaller,
    I'm just annoyed that if I open the same drawing in ACA 2014 its fine on the PC on the same monitor its just when I one it with ACA2022 I have the problem thats not a problem
    h
    2001-10
    Defragging the internets.
    345
    Try LWDISPLAY off.
    6,006
    you might check GRAPHICSCONFIG to see if hardware acceleration is turned on. Try turning it off. Perhaps your graphics card is not compliant?
  1. Replies: 3
    Last Post: 2006-10-24, 07:05 PM
  2. Paper space to model space
    By harry.77503 in forum AutoCAD General
    Last Post: 2004-12-16, 12:32 PM
  3. Change paper space back to model space
    By ojhicks-bhm in forum AutoCAD LT - General
    Last Post: 2004-11-01, 02:41 AM
  4. Model space into paper space
    By cad.33286 in forum AutoCAD General
    Last Post: 2004-07-16, 01:07 PM
  5. Toolbars, model space, paper space..
    By A James A in forum MDT - General
    Last Post: 2004-07-14, 04:06 PM
