Results 1 to 7 of 7
Thread: Unnecessary Projection Lines
    2005-01
    88
    Default Unnecessary Projection Lines
    Can anyone identify what do you call diagonal lines or looks like projection lines that appears on the drawing and how can I turn it off? Please see attached drawing picture. Thanks, Ted.
    Cairo - no, not Illinois
    5,069
    Default Re: Unnecessary Projection Lines
    nothing attached
    2005-01
    88
    Attachment did not go through...can you please show me how to attach an image/photo?
    2005-01
    88
    Hello Cadtag, thanks for the reply. I finally figured out how to insert image (Please find attached photo...now I am referring to those lines shown). Once zoomed in those lines respond accordingly. Thanks, Ted.
    Turlock, CA
    6,420
    I get those on one of our servers that doesn't have a graphics card designed for AutoCAD. You have to turn off hardware acceleration in the GRAPHICSCONFIG command.
    Here's a page that will help you find an approved graphics card.
    C:> ED WORKING....
    LinkedIn
    2005-01
    88
    Thanks Ed, problem solve!
    Turlock, CA
    6,420
    Turning off hardware acceleration will cause AutoCAD to perform a little slower. Depending on the size and complexity of your work, you may not notice this. After looking at the site I linked to, you notice that your card is on the list, you may just need to update your driver. And then you can turn hardware acceleration back on. Updating to the latest driver may work even for for a non-supported card.
    Also, you don't need to use your camera to do a screen capture. Windows has built in software. Use the Print Screen button on your keyboard or use Programs>Snip & Sketch. Then attach the png/jpeg to your post, not a pdf though. The forum has built-in viewers for image files.
    C:> ED WORKING....
    LinkedIn
  1. Tactic, for unnecessary changes?
    By Nubi-CAD in forum CAD Management - General
    Last Post: 2014-06-26, 04:11 PM
  2. 2012: Nested family cut lines showing as projection lines
    By humphrey.ben780631 in forum Revit Architecture - Families
    Last Post: 2011-10-21, 06:21 PM
  3. Black surface projection lines print slightly coloured.
    By karalyn.patrick in forum Revit Architecture - General
    Last Post: 2009-04-07, 10:46 AM
  4. Projection lines halftoned
    By arabatzis in forum Revit Architecture - General
    Last Post: 2006-10-16, 07:25 PM
  5. Eliminate unnecessary project folders created with new drawings
    By scorpioncure in forum AutoCAD Civil 3D - General
    Last Post: 2006-07-19, 12:28 PM
