Thread: Multiply a value in mm with a unit-less value (type ul) the result is 10 times larger, why?
    2022-07
    Default Multiply a value in mm with a unit-less value (type ul) the result is 10 times larger, why?
    Hi!
    I'm using parameters in my design to speed up changes and run into a strange problem.
    If I multiply a value in mm with a unitless value (type ul) the result is 10 times larger than it suppose to be. Why?
    See my attachment for understanding.
    Patrik
    Turlock, CA
    6,378
    Default Re: Multiply a value in mm with a unit-less value (type ul) the result is 10 times larger, why?
    Welcome to AUGI.
    What happens if you add some more parenthesis? (PlateW - (((NoRows-1mm) * 8 ul) + 4 mm) * 4 ul) /AA
    Also, instead of posting a Word file, please use the forum tools to post a picture (jpeg or png). That way users don't have to download anything. They can use the forum's image preview.
    C:> ED WORKING....
    2022-07
    Quote Originally Posted by patrik.hertel801199 View Post
    Hi!
    Patrik
    Adist (mm) = Cdist (mm) * Arel (mm)
    Try to modify the equation this way:
    Adist (mm) = Cdist (mm) * Arel (mm) / 1 mm
    2006-04
    Hi!
    Patrik
    Simple, Inventor internally calculates distances in cm (centimeters). That's 10mm:=)))
    ul (unitless) means use native units, cm!
    See VBA programming examples or some API manual.
    Hi!
    Patrik
    Hi Patrik
    first of all , always make sure your unit settings are OK for all parameters. The red text in the entry-cells is red for a reason!!
    example : you calculate Adist (a distance or length with unit mm) from multiplying Cdist and Arel (both distance or length) : the result actually has a unit of square mm. you could either devide the result by 1 mm (since mm^2/mm = mm), but i think it is more likely that one of your inputs (Arel) is not a distance but just a number (unitless)
    cheers
    rob sman
  1. After install imperial unit template, library and want to add metric unit
    By 01chang in forum Revit Architecture - General
    Last Post: 2009-12-03, 09:14 PM
  2. Replies: 6
    Last Post: 2008-05-23, 12:41 PM
  3. Why, Why ohhh Why can I not properly paint a split face...
    By luigi in forum Revit Architecture - General
    Last Post: 2005-04-09, 02:29 PM
