Thread: 3D UCS & Background Color Settings
    2001-11
    236
    Default 3D UCS & Background Color Settings
    Hello folks,
    All my 2d color settings have been fine for many years now.
    However, I seem to be having some issues with setting the colors to my 3D work. Sometimes, the background would be all black as I would like, in simple object creation scenarios, and sometimes, it would be as in the attached files. I would like to have all black.
    Also, my UCS / Cube views always seem to be off, not a direct views as down the 'Z' axis. I would like to have the view straight down from the top to the bottom. The UCS views seem to be ok in Paper Space, through a Viewport. I am adding an image and the AutoCAD (2021) file for more explanation, in case my English here is not clear enough.
    Cheers
    100 Club Kevin.Sturmer's Avatar
    2015-12
    Kalispell, MT
    171
    Default Re: 3D UCS & Background Color Settings
    Enter DVIEW in the command line, select "Off"
  1. Replies: 2
    Last Post: 2012-11-01, 04:25 AM
  2. Replies: 1
    Last Post: 2009-07-22, 08:55 PM
  3. Replies: 0
    Last Post: 2008-10-07, 06:01 PM
  4. Copy Solid from one UCS to another UCS
    By roger_wall in forum VBA/COM Interop
    Last Post: 2007-02-01, 12:23 AM
  5. Replies: 4
    Last Post: 2005-07-08, 03:16 PM
