Thread: Insert vs classicinsert
    2007-07
    393
    Default Insert vs classicinsert
    When I make changes to an existing block with attributes and 'classicinsert' it into a drawing that has the old block, I'm asked if I want to redefine it, I click yes and cancel. Then I attsync it and all is good. But if I use the new 2021 insert, this doesn't happen. Does anyone know why? Thanks.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Insert vs classicinsert
    Starting in 2020 the INSERT (Command) Displays the Blocks palette, which you can use to insert blocks and drawings into the current drawing which is a nice interface especially for inserting blocks from another drawing. For the functionality you're looking for try the -INSERT (Command) which works the same way as in older versions and was always the easiest way to insert and redefine a block other than Design Center.
    2007-07
    393
    That's what classicinsert does, so I've made 'i' as a shortcut for 'classicinsert'. Might give Design Center a go, though, thanks for the info.
  1. Insert Sheet List - Won't insert
    By chris.klinert in forum ACA General
    Last Post: 2008-12-18, 03:45 PM
  2. Auto insert doors 6" from wall intersections?
    By m_cahoon14336 in forum Revit Architecture - General
    Last Post: 2004-02-24, 08:19 PM
  3. Change family type, or insert without host.
    By overcaffeined1745 in forum Revit Architecture - Wish List
    Last Post: 2003-11-10, 02:04 AM
  4. Insert doors and windows
    By Eric Stewart in forum Revit Architecture - Wish List
    Last Post: 2003-09-08, 02:57 PM
  5. Column Family insert elevation
    By Henry D in forum Revit Architecture - Families
    Last Post: 2003-05-09, 02:13 PM
