**After much tinkering, I was able to find a solution.**
Working on this block to array circles in different directions as the final shape needed is not a square/rectangle.
What I would like is for all the circles and grips to be on top of each other initially, however when I do that my second and third array base circles are 1 row beyond where they need to be.
I adjusted the second and third to starting positions to make them end up in correct position once I array them around, but would prefer everything to be stacked and appear as one initially if that's possible.
The pictures might explain it better than my words.
Also, when I array, the grips are extended beyond the circle unlike their initial positions, if that could be fixed also where the grips retain their positions if possible.
Here are the two block files:
Congruent.dwgConcentric.dwg
