Originally Posted by
Wish List System
Summary: dealing with thousands of triangles can be a bit of a pain in the butt, I figure the software chugs on Elevations because of a object count, not complexity
Description: If they were to change the routine to detect contours and the given mins and maxes of each elevation index, then they could make hatches using island boundaries instead. then each elevation would be one object across the entire surface. Would probably help with exports too when you end up with thousands of little triangles for every vertex in the surface. If the hatch ended up with only vertices around their perimeter, everything would benefit. Even printing, when you get finite triangle edges all over your plots.
Product and Feature: AutoCAD - API
Submitted By: sebastien795355 on 08/18/2022
