Thread: Xref reload loses color
    2022-09
    2
    Default Xref reload loses color
    In Drawing B, I attach Drawing A - A fairly complex site plan which contains several attached xrefs. After working in Drawing B for awhile, I switch to drawing A and make a couple of changes. Returning to Drawing B I follow the prompt to reload Drawing A. All the colors in the xref'd Drawing A turn to white. Regen and audit don't fix it. I am using AutoCAD Architecture 2023 and saving to version 2018.
    2005-06
    in the upper right corner
    3,495
    Default Re: Xref reload loses color
    Maybe you know this but I'll suggest it anyway,
    do you have "visretain" set to 1 in drawing B? (this locks in the layer properties from xrefs if you have modified them within the drawings the xrefs are in).
    Other then that, I have no idea..
    ..unless maybe you are in a layout with the "display plot styles" checked off within the page setup?
    Turlock, CA
    6,302
    Maybe you could try this. Rather than setting VISRETAIN to 0 and reloading the xref, you can right click on an xref layer in the Layer Properties Manager and select the options in the picture below. If you want to update all layer colors, just select All Layers instead.
    C:> ED WORKING....
  1. 2016: Reload XREF freezes non XREF layer
    By mmiles in forum AutoCAD General
    Last Post: 2016-05-14, 12:04 PM
  2. Replies: 0
    Last Post: 2009-01-31, 04:01 PM
  3. 2008 SCALE 1:100 xref xref xref xref- scale list issues
    By Apsis0215 in forum AutoCAD Customization
    Last Post: 2008-11-21, 08:17 PM
  4. Xref Reload Balloon
    By tomdillenbeck in forum AutoCAD General
    Last Post: 2005-08-24, 08:02 PM
  5. reload xref - layers
    By kca2.69080 in forum ACA General
    Last Post: 2004-06-02, 09:44 PM
Tags for this Thread
