Thread: Line table with just distance
    2010-06
    Vancouver, WA
    66
    Default Line table with just distance
    I have a boundary Line Adjustment and one of the requirements for recording is to show the distance from the building to the new boundary line.
    The scale needed for the required max sheet size makes the drawing somewhat congested. I would like to tag the lines and create a table that only shows take label and distance.
    Is this possible? if so how do I do it?
    Thanks in advance.
    - - - Updated - - -
    Quote Originally Posted by jpglisson View Post
    Thanks in advance.
    I should mention there are about 20 buildings and the new boundary jigjogs in and out around the buildings.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Line table with just distance
    You can edit the line table style to only show the distance. This would require removing the bearing column from the style. Is this what you are looking for?
    2014-08
    448
    Or you can use the easy method after you have everything labeled and table made, explode the table twice it becomes text and lines. Then if the table is to large as my are quite frequently on drawing with a lot of info and limit space I adjust the spacing between the lines of data which styles don't allow. I know you'll get alot don't explode it in Civil3D but sometimes you just need to do what works
    2010-06
    Vancouver, WA
    66
    Opie, that is what I would like.
    We do have several line styles that I could copy from.
    How do I go about doing that?
    Thanks
    2010-06
    Vancouver, WA
    66
    Thank you Opie.
    I figured it out.
    Thanks for your support
  1. Replies: 2
    Last Post: 2013-03-19, 08:19 PM
  2. Coordinate Array distance & move distance
    By nextvkin in forum Dynamic Blocks - Technical
    Last Post: 2011-07-12, 07:15 PM
  3. Distance command in Paperspace, returns Modelspace distance.
    By chuck_cantieny in forum AutoCAD General
    Last Post: 2006-09-21, 04:00 PM
  4. Distance Learning to far in the Distance?
    By stuntmonkee in forum Revit Architecture - General
    Last Post: 2005-08-23, 06:12 AM
