Thread: multileader procedure
    2003-08
    99
    Default multileader procedure
    Multileader with mtext is requiring mtext to be created and placed first before drawing leader. Suddenly reversed from normal procedure. What is the setting to get back to drawing multileader then typing in mtext?
    Turlock, CA
    6,409
    Default Re: multileader procedure
    When you enter the command, right+click at the first prompt and select 'leader landing first'.
    C:> ED WORKING....
    LinkedIn
    2003-08
    99
    I found that in the command prompt shortly after I posted the thread. I don't know how 'content first' got selected. Thanks!
  1. Structural Roof Framing Procedure
    By razorx1858 in forum Revit Architecture - General
    Last Post: 2004-12-06, 09:45 PM
  2. Scale Change Procedure
    By jcronburg in forum VBA/COM Interop
    Last Post: 2004-06-17, 03:18 PM
Tags for this Thread
