Thread: Dependent AND Offset section cuts?
    2016-09
    10
    Default Dependent AND Offset section cuts?
    I have an offset section cut for a large corporate headquarters building. The section wouldn't fit on a sheet, so I also had to create a dependent view to split the section. The offset to the section is in 1 corner of the building, so I can't split the view where the offset is to make it simple. Is there a way to still hide the center of the section cut, or do I have to just live with the line going all the way through the building? In retrospect, I probably should have just duplicated the view instead of using a dependent view, but I'm too far down the road now to change it, I think.
    Has anyone else run into this, and if so, is there a work-around that someone has come up with?
    Traci
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Default Re: Dependent AND Offset section cuts?
    Quote Originally Posted by tracigarner68734770 View Post
    Traci
    Yes, the "Gaps in Segments" mark is still available on the section line. With a split section (offset), it creates three gaps - one in each segment of the split and another along the offset direction:
    Drag the dot grips to keep as much or little of the section line(s) at you want.
  1. Replies: 2
    Last Post: 2014-04-13, 07:56 AM
  2. Dependent views not acting dependent
    By mjdanowski in forum Revit MEP - General
    Last Post: 2010-08-16, 09:11 PM
  3. Structure 2011 Section Cuts- Meshes and or solids???????
    By ree.espinoza in forum Revit Structure - General
    Last Post: 2010-08-07, 06:02 PM
  4. dependent to non-dependent?
    By Les Therrien in forum Revit Architecture - Families
    Last Post: 2009-01-22, 10:03 PM
  5. wall section/ building section tags/cuts
    By belyo in forum Revit Architecture - General
    Last Post: 2006-12-13, 07:39 PM
