Thread: Set baseline and region parameters
    2009-11
    Raleigh, NC
    944
    Default Set baseline and region parameters
    When creating a corridor what do are the technical specifics being done when I leave the box checked to "Set baseline and region parameters"?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Set baseline and region parameters
    What happens after you click OK to continue the process if the box is checked? What happens when that box is unchecked?
    There may or may not be a dialog that opens after you click OK to set those parameters.
    2009-11
    Raleigh, NC
    944
    This did prompt the dialogue box to set the baseline and region parameters.
  1. 2018: Set assembly from elevation target and ignore vertical baseline
    By uhkhu in forum AutoCAD Civil 3D - General
    Last Post: 2018-07-23, 07:17 PM
  2. RA2008 - Vertical Baseline for Linebased Families
    By clog boy in forum Revit Architecture - Wish List
    Last Post: 2007-08-27, 01:44 PM
  3. Replies: 0
    Last Post: 2006-07-22, 05:32 PM
  4. Running dimension or baseline dimension?
    By aliya14 in forum Revit Architecture - General
    Last Post: 2005-06-09, 08:55 AM
  5. wall display below baseline
    By dberg.47064 in forum ACA General
    Last Post: 2005-04-11, 01:15 PM
