NalkCZ
Hi there,
I'm adjusting tool for printing of PDFs. I am forced to use (per department standard) Adobe PDF printer. Is there a way to fill/avoid that pop-up window and instead fill this information via LISP?
I have Page Setups for every size layout and one for PDF for each of them as well with " PDF" added to the name so "11×17" for the hardcopy and "11×17 PDF" for the PDF file.
Checked and even with Page Setup set to Adobe PDF I do not get any dialog box plotting the current layout to PDF in the drawing's folder using macro ^C^C^P(pdfPlot) using the following code as long as it's not already open in Adobe:
(defun getCurrentPagesetup (layout / lst PSname PSdim data)
(setq lst (dictsearch (namedobjdict) "acad_layout")
lst (dictsearch (cdar lst) layout)
(setq
PSname (cdr(assoc 1 lst))
lst (member '(100 . "AcDbPlotSettings") lst)
data (cadr lst)
PSdim (PaperSize)
(princ "\nPSdim = ")(princ PSdim)
(princ "\n")
(cond
((= PSdim "8½×11")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "8½×11" "8½×11 PDF")))); .regen
((= PSdim "11×8½")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "11×8½" "11×8½ PDF")))); .regen
((= PSdim "8½×14")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "8½×14" "8½×14 PDF")))); .regen
((= PSdim "14×8½")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "14×8½" "14×8½ PDF")))); .regen
((= PSdim "11×17")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "11×17" "11×17 PDF")))); .regen
((= PSdim "18×24")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "18×24" "18×24 PDF")))); .regen
((= PSdim "24×36")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "24×36" "24×36 PDF")))); .regen
((= PSdim "22×34")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "22×34" "22×34 PDF")))); .regen
((= PSdim "34×22")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "34×22" "34×22 PDF")))); .regen
((= PSdim "36×48")
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "36×48" "36×48 PDF")))); .regen
(T (princ "\nDrawing not saved!"))
(SetCurrentPageSetup (vla-get-activedocument (vlax-get-acad-object)) PSdim)
(PaperSize)
(defun QuickPlot ( / CPgSetup pathPDF)
(setq CPgSetup(getCurrentPagesetup (getvar "ctab"))
pathPDF (strcat (getvar "DWGPREFIX")(vl-filename-base (getvar "dwgname"))" - "(getvar "ctab"))
(if CPgSetup
(progn
(vl-file-delete (strcat CPgSetup)) ;http://forums.augi.com/showthread.php?173337-Check-if-PDF-is-open-Delete-if-not&p=1341076&viewfull=1#post1341076
(command "_.-PLOT" "No" "" "" "" "" "" "Yes")
(if (> (getvar "cmdactive") 0)
(progn
(command "No")
(princ (alert (strcat pathPDF " cannot be plotted because it's Open in Adobe Acrobat!")))
(princ (strcat pathPDF " saved."))
(princ)
(defun pdfPlot ( / CPgSetup pathPDF)
(if CPgSetup
(progn
(vl-file-delete (strcat CPgSetup " PDF")) ;http://forums.augi.com/showthread.php?173337-Check-if-PDF-is-open-Delete-if-not&p=1341076&viewfull=1#post1341076
(or(vl-string-search " PDF" CPgSetup)(setq CPgSetup(strcat CPgSetup " PDF")))
(command "_.-PLOT" "No" "" CPgSetup "" pathPDF "No" "Yes")
(progn
(command "No")
(princ)
While it includes calls to Lee Mac's Steal from Drawing to import Page Setups from my template drawing it's not required if the Page Setups are already in the drawing.
