Thread: Adding Section Views
    2009-11
    Raleigh, NC
    941
    Default Adding Section Views
    I have added 2 more Sample Lines.
    How do I add the section views for SL-1 and SL-2 at station 0+22.61 & 1+00.00
    2017-09
    63
    Default Re: Adding Section Views
    Under Home, Section Views, Create Section View......you can do each one separate or you can recreate all at once using the Create Multiple Views.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Unless you have done any annotations on the previously created sections, I would just recreate the section views for all of the samples lines in that group. It may require adjusting your sheet views, but it could be quicker than trying to fix this issue.
    Granted, it would be nice to know how to insert section views from a sample line group.
  1. 2017: Adding information in the section views (Labels, centerlines, dimensions, etc)
    By andres_t in forum AutoCAD Civil 3D - Corridors
    Last Post: 2017-01-26, 07:07 PM
  2. 2015: Multiple section views no longer working after adding custom sub-assembly.
    By Barry Huston in forum AutoCAD Civil 3D - Sections
    Last Post: 2015-10-22, 11:39 AM
  3. Section Views, fix the seperation and vizability across plan views
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2012-07-24, 02:46 PM
  4. Pipe network structions to show structure section in section views
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2010-10-06, 01:04 AM
  5. Section Views and Section View Groups
    By WScottAllenPE in forum AutoCAD Civil 3D - Sections
    Last Post: 2010-07-28, 03:25 PM
