Thread: SHP import/export utility 2022
    2004-06
    Slidell, Louisiana
    948
    Default SHP import/export utility 2022
    Has anyone had a problem with this app/update? I installed and used it once, now it won't initialize. I get a message for a Log File that references an imperial template.
    Also, I don't see it on my Autodesk Desktop App under updates anymore.
    Active Member dotson's Avatar
    2005-01
    52
    Default Re: SHP import/export utility 2022
    Quote Originally Posted by rmk View Post
    Watch out for the numeric values in the .DBF file. I can't speak for the current version but initial releases used integers and your numbers would lose their decimal precision. To check, after you do an export, start Excel, close the current spreadsheet, then drag/drop the created .DBF file onto Excel (but don't save!).
  1. 2023: Where is SHP import/export tool readme?
    By Ed Jobe in forum AutoCAD Civil 3D - General
    Last Post: 2022-06-17, 01:40 PM
  2. 2022: C3D 2022 - Export Geopak (GPK)
    By dkensil in forum AutoCAD Civil 3D - General
    Last Post: 2021-09-22, 07:35 PM
  3. Replies: 0
    Last Post: 2015-08-07, 05:37 PM
  4. import shp dialog doesn't show shp files in directory
    By gisdude in forum AutoCAD Map 3D - General
    Last Post: 2008-02-15, 01:08 AM
  5. Inopso IFC Import/Export utility
    By dbaldacchino in forum Revit - In Practice
    Last Post: 2006-10-26, 09:21 PM
