I'm having problems with duplicate geometry in one of my drawing. Both overkill and mapclean are failing to clean this up! Any deas?
Explain what type of duplicate geometry you're trying to get rid of and if you want to get rid of it if it's on another layer.
Lots of options for the overkill command and they're all stored in the Windows registry so if you change any they stay changed until you change them again.
They can be turned on or off with lisp but you figure out what settings you need on and which need to be off and wanted help with code to modify those settings you would need to ask in the propper forum.
Yeah, I suspect that all the the things I'm trying will work, I'm just not using the correct settings. The geometry is an exact duplicate of the geometry I'm trying to hold. I was looking for something quick and easy as this is a very powerful program. I'm certain I'm just doing this wrong.
- - - Updated - - -
I tried......no luck. Thanks, though.....
