Thread: Overkill
    2015-10
    73
    Default Overkill
    I'm having problems with duplicate geometry in one of my drawing. Both overkill and mapclean are failing to clean this up! Any deas?
    Cairo - no, not Illinois
    5,069
    Default Re: Overkill
    You can try WEEDFEATURES in Civil3d...
    Tallahassee, FL USA
    3,667
    Explain what type of duplicate geometry you're trying to get rid of and if you want to get rid of it if it's on another layer.
    Lots of options for the overkill command and they're all stored in the Windows registry so if you change any they stay changed until you change them again.
    They can be turned on or off with lisp but you figure out what settings you need on and which need to be off and wanted help with code to modify those settings you would need to ask in the propper forum.
    2015-10
    73
    Yeah, I suspect that all the the things I'm trying will work, I'm just not using the correct settings. The geometry is an exact duplicate of the geometry I'm trying to hold. I was looking for something quick and easy as this is a very powerful program. I'm certain I'm just doing this wrong.
    - - - Updated - - -
    I tried......no luck. Thanks, though.....
  1. Overkill - Any ideas on how I can clean up this drawing?
    By fletch97 in forum AutoCAD General
    Last Post: 2006-03-21, 06:33 PM
  2. Overkill for AutoCAD 2002
    By chrisr in forum AutoCAD General
    Last Post: 2006-03-16, 02:29 PM
  3. Overkill Error
    By BrenBren in forum AutoCAD General
    Last Post: 2005-08-24, 12:10 AM
  4. Overkill it isn't a Rock N Roll Band
    By Rick.B in forum AutoCAD Tips & Tricks
    Last Post: 2005-04-04, 06:41 PM
  5. Overkill freezes acad
    By Wanderer in forum AutoCAD General
    Last Post: 2004-08-19, 09:38 PM
