Thread: Update Title Blocks
    2011-09
    5
    Default Update Title Blocks
    I am trying to write a script to update all of my Title Blocks with a new logo and a new date. The location of my title block, which is a block is:
    X:AutoCadDrawings03/BLOCKR14/FormatA2.dwg
    2011-09
    5
    Default Re: Update Title Blocks
    I currently have to update all of my Drawings one at a time--opening the drawing and clicking on the titleblock, clicking on the date and changing the date, and then inserting the new updated title block and choosing redefine.
    2021-06
    Hey did you found any solution for this I have been trying this a lot but having the same issue.
    in the upper right corner
    3,508
    Quote Originally Posted by mariacb View Post
    You can write a script that inserts and redefines the existing block with a new block.dwg
    The new block needs to have the same name as the old block to redifne it.
    You would need to have your block and file names and path, the example shown has the file path X:\
    example script code:
    -insert
    "title block file name=X:\title block file name.dwg"
    0,0,0
    erase
    last
    qsave
  1. Update Title Blocks
    By drovang710500 in forum AutoLISP
    Last Post: 2013-12-18, 02:16 AM
  2. Replies: 5
    Last Post: 2013-05-18, 01:44 PM
  3. update title block in multiple tabs
    By peter.shoemark in forum AutoLISP
    Last Post: 2011-11-14, 02:48 PM
  4. Dynamic Blocks in Title Blocks
    By tim.j.sparks in forum Dynamic Blocks - Technical
    Last Post: 2011-03-01, 06:08 PM
  5. Replies: 1
    Last Post: 2007-01-05, 01:38 AM
