Thread: PAD Block with Lot# & FF Elev
    2017-03
    22
    Default PAD Block with Lot# & FF Elev
    I have an attributed dynamic block that includes a Dynamic rectangle that represents the pad boundary. It's dynamic properties are width & Depth and alignment with the building line. That part is very nice, but it is a total pain to edit when the PAD elevations change. It also includes an attribute that we edit for the lot#, FF text, and and attribute that we edit with the FF Elevation. My personal opinion is that attributed blocks are just a poor, inefficient way to do thing these days. I am trying to replace this block with a surface elevation label that includes all these items, so once we place the label we never have to edit the elevation value, but I can't get it to work. If deriving the lots #'s is possible then that would be even better. I need the elevation from inside the pad boundary from the FG surface plus a foot, but the text needs to align with the building line.
    Best I can come up with is to delete the FF value from the dynamic block and continue using the block, then adding a label that would put the FF elev in the right location and rotation, but an struggling getting that to work.
    Can anyone help with a solution?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: PAD Block with Lot# & FF Elev
    With a C3D surface label, you can have a reference to a parcel. This should allow you to label the lot number along with the elevation of the surface at the label's insertion point.
    Rotating that label will be a manual task unless you can get a .net solution created to adjust the RotationAngle property of the label. AutoLISP does not have access to that property for some reason.
  1. 2012: Can a pad tell you how much earth needs to be removed from the site to meet the pad?
    By foley.g.andrew481900 in forum Revit Architecture - General
    Last Post: 2013-03-21, 10:37 AM
  2. Curb & Gutter Assembly on Parking Lot Feature Lines?
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2011-08-17, 11:55 PM
  3. 2010 3D Mechanical Pad (Housekeeping Pad)
    By michaelmerda in forum ACA/AMEP Tips & Tricks
    Last Post: 2010-04-16, 10:46 PM
  4. Existing pad vs new pad cut and fill
    By ctc in forum Revit Architecture - General
    Last Post: 2009-10-02, 12:32 PM
  5. Structural - Concrete Pad (PRD-PAD)
    By ewhite in forum Dynamic Blocks - Sharing
    Last Post: 2006-09-11, 06:49 PM
Tags for this Thread
