Re: Export To Shapefile
Summary: Export features as ESRI Shapefile
Description: Currently the only method to export features from the Task Pane in AutoCAD Map is an SDF format. Being able to export features directly to an ESRI shapefile format would be very useful. Currently the user has to export to SDF, then import the SDF as a drawing entity and then export as a SHP.
Product and Feature: AutoCAD - 3D
Submitted By: msharp on 10/24/2022
Take a look at this video: https://www.youtube.com/watch?v=x9Xdha6oG1w
You need to assign a coordinate system first then use the MAPEXPORT command and set the export to ESRI Shapefile.
This wish has been reported as granted and already in the software.
- You may not post replies
- You may not edit your posts
Forum Rules
