Thread: Elevation Callout Tag - Not Showing
    2014-05
    3
    Default Elevation Callout Tag - Not Showing
    We are working with cloud sharing using Revit 2022.
    In my company's template, The Callout Tag for elevations only shows in one view. The 'bubble' shows everywhere but the 'arrow' is missing. It only seems effect the elevations in the template itself. Any new elevations created show both.
    Does anyone have advice on what is causing this and if there is a way to create it?
    Thank you.
    2005-06
    in the upper right corner
    3,508
    Default Re: Elevation Callout Tag - Not Showing
    possibly check the properties of the elevation view that is showing (or in the template if used) to see if it is "hiding at scales courser than"
    For instance: the plan it's showing the elevation callout in is within the scale(s) allowed, and not showing in the ones courser than ones allowed?
    just a shot in the dark
  1. Custom Section Tag & Callout Tag
    By ryan.rosche in forum Revit Architecture - General
    Last Post: 2010-09-22, 10:20 PM
  2. elevation tag / spot elevation tag location
    By frank.richarz in forum Revit Architecture - General
    Last Post: 2010-06-09, 02:30 PM
  3. Revit 2010 - Material Tag Not Showing in Floor Plan Callout
    By ruthellenwilliams in forum Revit Architecture - General
    Last Post: 2009-07-09, 04:37 PM
  4. callout tag vs section tag
    By scoe in forum Revit Architecture - General
    Last Post: 2006-09-07, 08:19 PM
  5. Question: Elevation tag not allowed in callout plan?
    By GS Fulton in forum Revit Architecture - General
    Last Post: 2006-02-09, 07:20 PM
Tags for this Thread
