Thread: Launch the layer manager form Autolisp .lsp
    2010-01
    18
    Default Launch the layer manager form Autolisp .lsp
    AutoCAD.
    Is it possible to launch the layer manager form Autolisp .lsp?
    (command ".-layer")
    Not the desired result.
    Any idea?
    Tallahassee, FL USA
    3,619
    Default Re: Launch the layer manager form Autolisp .lsp
    You can do anything you want with layers using lisp but you're using the wrong command.
    Try (command ".LAYERPALETTE") https://www.cadtutor.net/forum/topic...comment-555676
    (command ".-layer") in 2022 version returns:
    Current layer: "0"
    Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]:
    (command ".+layer") in 2022 version returns:
    Specify filter [All/All Used Layers/Unreconciled New Layers/Viewport Overrides] <All>:
    Command options vary depending on what version of AutoCAD you're using but using lisp instead is more consistent between versions.
    2010-01
    18
    Thank you Tom, the best solution! This is also an option: (initdia 1)(command "_LAYER") to start the dialog. But just start, no other control is possible this way. But not so stable.
  1. Launch AutoLISP program from VB Macro
    By johannvonspiralspine in forum VBA/COM Interop
    Last Post: 2008-04-27, 04:16 AM
  2. Cut Geometry, Solid form, Void form
    By mmolina in forum Revit Architecture - General
    Last Post: 2005-05-11, 09:33 PM
  3. LAYER MANAGER DELAY IN 2005 LT & LSP
    By JKVMAD in forum AutoCAD LT - General
    Last Post: 2004-12-14, 05:52 PM
