Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Surface and border failures
  1. #11
    2017-11
    4
    Default Re: Surface and border failures
    no, nothing else there. Equally weird is that I deleted the surface, and recreated it, but started from the outside in -- selecting the MEG feature lines first, adding the boundary, and then adding back in the interior feature lines. Voila!! it showed up properly. I'm not sure what lesson to lean from that, other that C3D is weird.
    Potentially the build order was off? Moving the outside border to the bottom of the build order in the Surface properties usually fixes this issue for me.
    ~Andy
  2. #12
    Cairo - no, not Illinois
    5,069
    interesting. next time will try that (and knowing C3D, there _will_ be a next time)
  1. Revit MEP Success or Failures
    By clarkmorgan in forum Revit MEP - General
    Last Post: 2008-05-07, 06:48 PM
  2. surfing for failures
    By perezdeftone1988 in forum AutoCAD General
    Last Post: 2004-09-02, 08:43 PM
  3. fillet failures
    By perezdeftone1988 in forum New Forum Users (Non technical)
    Last Post: 2004-09-02, 07:35 PM
  4. Autocad Authorization Code Failures
    By bmkannan in forum Software
    Last Post: 2004-06-30, 03:19 AM
  5. Installation Failures!!!
    By sbrown in forum Revit Architecture - General
    Last Post: 2004-01-14, 01:03 PM
