310mjh802856
Okay, with help from ToanDN on the Autodesk Revit Forum I got this to work. I created to new planes to define the x and y dimensions to the circle. Then placed points hosted and each of the four perimeter reference lines and used Hosted by Intersection to constrain the point in position. I then placed another set of four points the quadrants of the circle, and finally added a reference line connecting the point at the quadrant and the corresponding one on the perimeter reference line. If done properly the points, under properties both Driving Curve(s) and Driven by Host are checked and the value of Normalized Curve Parameter will be grayed out (since the position is controlled by the intersection.)
