Thread: Band Set
    2009-11
    Raleigh, NC
    944
    Default Band Set
    Alignment will be at BOC with existing grade profile. I will be creating existing & proposed offset profiles that will will need the to be the information in the Band Set.
    Can I create a Band Set that will a component of the offset profiles?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Band Set
    You can have different profiles associated with that alignment labeled using band sets. I have not had success with labeling superimposed profiles in a band set.
  1. 2013: Set Default Profile Band Style
    By nobodyhome710175 in forum AutoCAD Civil 3D - General
    Last Post: 2016-09-14, 10:55 PM
  2. 2014: Pipe data source suddenly empty on Profile View band set
    By mermercad in forum AutoCAD Civil 3D - Pipes
    Last Post: 2014-02-03, 05:35 PM
  3. Replies: 0
    Last Post: 2004-09-21, 08:00 PM
  4. ARC with "rubber band"
    By mjsregister in forum VBA/COM Interop
    Last Post: 2004-08-09, 06:59 PM
