Results 1 to 10 of 10
Thread: Nested block and coordinates
    2022-10
    12
    Question Nested block and coordinates
    Hello there,
    I'm facing problem working with nested blocks.
    I have block - usually nested at third level (if I cound correctly, that block I can select directly is 1st level, than block editor goes to 2nd level and only there I can pick my block and open it as 3rd level) that I would like to know its coordinates (basically insertion point, specifically the Z elevation). I tried nentsel and working it but I do not understand much the syntax and information I am getting.
    As far as I can tell, I'm getting coordinates relative to what is happening inside of blocks (so Z says it is -24 when I can tell by exploding that it is 1200something). But if I try to also entsel and figure out coordinates from block, main block (1st level) is inserted to 0,0,0 so I dont know how to connect those different coordinates. I would like to have actual coordinate of this nested block in context of drawing so that I can use coordinates to build next steps with them.
    I've looked into couple of LISPs but they mostly list out block info into command line or external file and I am having hard time to extract just few bits I might need. Could anyone dumb it down for me?
    TLDR - block X nested in block B which is in block A - I would like coordinates of block X in context of actual drawing as I would like to work with those coordinates to do further steps in my routine (using them to add select or add other objects).
    Turlock, CA
    6,420
    Default Re: Nested block and coordinates
    It's not really clear what you want. I suggest that you post a sample file and describe what steps you are taking and what you want to achieve.
    C:> ED WORKING....
    LinkedIn
    2016-10
    7
    You can transform the insertionpoint with the refgeom function by gile found here:
    https://www.theswamp.org/index.php?t...1150#msg331150
    Its complicated stuff, but if you insert the block ename it returns a matrix to use on the insertionpoint to convert it to the point actual point you want.
    2016-10
    7
    Quote Originally Posted by robske736291 View Post
    Ok, it removed my link to theswamp... index.php?topic=27508.msg331150#msg331150
    You can also find it if you google for refgeom...
    2022-10
    12
    I've attached simplified upload friendly version of what I am working with.
    I have block A that contains couple of smaller things (I've placed just rectangles to put something in) and block B that is the main item. Block B is made out of some parts I don't need to work with (named that block "legs") and Block C. Block C is object from which I want to know its insertion point with coordinates relevant to being in drawing and not in block editor.
    @robske736291 - I'll try to have a look, but as you say, it is bit complex.
    Turlock, CA
    6,420
    Sorry, but our anti-spam software does that if you don't have more than 5 posts. We get a lot of spammers creating a new account just so they can post a link to their website.
    I'll repost it.
    C:> ED WORKING....
    LinkedIn
    2016-10
    7
    Funny that you pick an example with all the base points at 0,0,0 .
    I wrote an getInsertionPoint function to find all the nested points.
    Its a recursive function that transforms the points each time it is nested.
    That way in the end you should get the absolute coordinates of the blocks insertion point.
    It returns a list with all the block names it is nested in so you can find the one you want.
    (defun c:test (/ ent)
    	(setq ent (car (entsel)))
    	(setq insertionPoints (getInsertionPoints nil ent)) ; Get insertion points
    	(foreach pnt insertionPoints ; Draw them to show that is works
    		(entmakex (list '(0 . "POINT") (cons 10 (cadr pnt))))
    	insertionPoints ; Return info
    (defun getInsertionPoints (prefix ent / blockName ent enx mat nestedBlocks thisBlock)
    	(setq enx (entget ent))
    	(setq blockName (cdr (assoc 2 enx))) ; Block Name
    	(setq mat (Mat:refgeom ent)) ; Transfromation matrix for this block
    	(setq thisBlock ; Insertion Point for this block
    		(list
    			(cond (prefix (strcat prefix ":" blockName)) (blockName)) ; Block name with prefix
    			(trans (cdr (assoc 10 enx)) (cdr (assoc 210 enx)) 0) ; Insertion Point
    	(if (setq ent (tblobjname "BLOCK" blockName))
    		(while (and ent (setq ent (entnext ent))) ; loop though items inside block
    			(if (= (cdr (assoc 0 (entget ent))) "INSERT") ; If a nested block is found
    				(progn
    					(setq nestedBlocks
    						(mapcar
    							(function
    								(lambda (blk) ; Go through items retuned from getInsertionPoints
    									(list
    										(car blk) ; Keep block name the same
    										(mapcar '+ (Mat:mxv (car mat) (cadr blk)) '(0 0 0) (cadr mat)) ; Transform with refgeom matrix
    							(getInsertionPoints (car thisBlock) ent) ; Go deeper
    	(cons thisBlock nestedblocks)
    ;;; RefGeom - gile                                                              ;;
    ;;; Returns a list whose first item is a 3x3 transformation matrix and          ;;
    ;;; second item the object insertion point in its parent (xref, block or space) ;;
    (defun Mat:refgeom (ent / ang enx mat ocs)
    				ang (cdr (assoc 050 enx))
    				ocs (cdr (assoc 210 enx)))
    	(list
    		(setq mat
    						(Mat:mxm
    							(mapcar
    								(function (lambda (v) (trans v 0 ocs t)))
    									(1.0 0.0 0.0)
    									(0.0 1.0 0.0)
    									(0.0 0.0 1.0)
    							(Mat:mxm
    								(list
    									(list (cos ang) (- (sin ang)) 0.0)
    									(list (sin ang) (cos ang) 0.0)
    									'(0.0 0.0 1.0)
    								(list
    									(list (cdr (assoc 41 enx)) 0.0 0.0)
    									(list 0.0 (cdr (assoc 42 enx)) 0.0)
    									(list 0.0 0.0 (cdr (assoc 43 enx)))
    		(mapcar '-
    			(trans (cdr (assoc 10 enx)) ocs 0)
    			(Mat:mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))))
    ;;; Matrix x Vector - Vladimir Nesterovsky                    ;;
    ;;; Args: m - nxn matrix, v - vector in R^n                   ;;
    (defun Mat:mxv (m v)
    	(mapcar (function (lambda (r) (apply '+ (mapcar '* r v)))) m)
    ;;; Matrix x Matrix - Vladimir Nesterovsky                    ;;
    ;;; Args: m,n - nxn matrices                                  ;;
    (defun Mat:mxm (m n)
    	((lambda (a) (mapcar (function (lambda (r) (Mat:mxv a r))) m)) (Mat:trp n))
    ;;; Matrix Transpose - Doug Wilson                            ;;
    ;;; Args: m - nxn matrix                                      ;;
    (defun Mat:trp (m)
    	(apply 'mapcar (cons 'list m))
    (princ)
    - - - Updated - - -
    I'll repost it.
    I understand, also editing posts doesn't work probably because of the same reason.
    Guess I'll have to post more then
    2022-10
    12
    @robske736291 Thank you for the code!
    There is lot of 0,0,0 in the work process I'm dealing with and I feel it maybe adds bit of difficulty to the task, so that is why I picked it. It is somewhat new to me as I previously worked somewhere where we would not nest blocks like this, but it has its own logic here which seems reasonable enough.
    (("Block A" (0.0 0.0 0.0)) ("Block A:Block B" (0.0 0.0 0.0)) ("Block A:Block B:legs" (0.0 0.0 0.0)))
    I'm getting this and what I am interested in is actually Block C which is not here. It would probably be "Block A:Block B:Block C". But I think using what I've made in my attempts and mostly from what you've given me here, I should be able to piece it together. So once again thank you for the help.
    @Ed Jobe thank you for reposting the link.
    2016-10
    7
    Ah yes, I didn't add the nested items to a list but replaced the variable each time.
    I've added append and now it should work:
    		(list
    				(progn
    					(setq nestedBlocks
    						(append
    							(mapcar
    								(function
    										(list
    							nestedBlocks
    2022-10
    12
    Absolutely amazing!
  1. 2014: DWG Nested Inside Detail Comp. > Nested Inside Profile > Nested Inside Window
    By edu.rocha.tavares in forum Revit Architecture - Families
    Last Post: 2013-11-26, 06:46 PM
  2. 2013: How do I export to IFC with project coordinates and not real world coordinates?
    By m.knutsson in forum Revit Architecture - General
    Last Post: 2013-10-15, 06:54 AM
  3. Project Coordinates, Shared Coordinates, and the new Survey Point
    By Wes Macaulay in forum Revit - Platform
    Last Post: 2012-07-05, 06:20 PM
  4. Replies: 0
    Last Post: 2007-09-30, 02:56 PM
  5. How do I translate Nested Block coordinates?
    By danderson.71652 in forum VBA/COM Interop
    Last Post: 2006-02-09, 04:21 PM
