Thread: Sheet Set Manager will not find Custom Property
    2009-11
    Raleigh, NC
    944
    Default Sheet Set Manager will not find Custom Property
    Sheet Set Manager will not find Custom Property inside the block.
    It will find it if I create an Attribute outside the block as shown in image 3
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,104
    Default Re: Sheet Set Manager will not find Custom Property
    Does the currently opened Sheet Set contain that field?
    2009-11
    Raleigh, NC
    944
    It does, Just started here and I want to add that we have computer desktops that are remote. Our Civil3D runs on "Citrix" in another stae. It seems as though that is a weird wrinkle on some of the functions sometimes.
    2002-01
    jUSt Here (a lot)
    9,104
    If you know the name of the field, you can type it into the Custom Property Name text box.
  1. Adjust Custom Property Order in Sheet Set Manager
    Last Post: 2023-04-03, 05:18 PM
  2. Change a lookup based on Sheet Set Manager custom property
    By carlosrgns in forum AutoCAD Sheet Set Manager
    Last Post: 2017-01-18, 09:34 PM
  3. Replies: 1
    Last Post: 2014-11-20, 12:27 AM
  4. Current Sheet (Set) Custom in Sheet Set Manager
    By Havoc501 in forum AutoCAD Fields
    Last Post: 2012-10-04, 03:41 PM
  5. Replies: 1
    Last Post: 2008-05-16, 05:57 AM
