Thread: Lower Case field
    2009-11
    Raleigh, NC
    933
    Default Lower Case field
    The DrawnBy Custom Prorperty is all upper case by the field is producing lower case.
    Can this be corrected?
    2001-10
    Defragging the internets.
    350
    Default Re: Lower Case field
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,083
    Look at the properties of the field where you are placing it within a text or attribute object. There is an option to change the case of the data.
  1. 2013: Sheet set manager text a mix of upper case & lower case
    By nextvkin in forum AutoCAD Sheet Set Manager
    Last Post: 2018-03-27, 09:26 PM
  2. Replies: 3
    Last Post: 2007-01-09, 12:42 PM
  3. Keynote table Upp case to Lower case
    By cdoucet in forum ACA General
    Last Post: 2006-09-13, 04:21 PM
  4. Changing from UPPER case to lower case
    By IamSnave in forum AutoCAD General
    Last Post: 2005-02-09, 10:30 PM
  5. Layer names from lower to upper case
    By dqueen in forum AutoCAD Customization
    Last Post: 2004-06-23, 03:05 PM
