Thread: Flatten command
    2009-11
    Raleigh, NC
    922
    Default Flatten command
    How can I get the Flatten command to work?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,057
    Default Re: Flatten command
    What are you trying to flatten?
    2020-08
    3
    I have ran into the (command) / (command-s) barrier on other commands before as well. I generally have to save and shut down C3D completely. Fire it back up and it works normally.
    Turlock, CA
    6,301
    2
    The file flattensup.lsp has a bunch of references to (command). You could replace them with (command-s) to fix the problem.
    C:> ED WORKING....
    2021-05
    tankyou tankyou
  1. Flatten Z cords without using the Flatten command.
    By Doodlemusmaximus in forum AutoCAD General
    Last Post: 2016-01-08, 02:26 PM
  2. Problem w/ Flatten command
    By cwjean76 in forum AutoCAD General
    Last Post: 2008-04-16, 04:54 PM
  3. Replies: 12
    Last Post: 2006-12-08, 06:37 PM
  4. Flatten Command or equivalent
    By fdebolt in forum AutoCAD General
    Last Post: 2006-09-22, 12:10 AM
  5. Old "flatten" won't flatten
    By laratoola85973 in forum AutoCAD General
    Last Post: 2006-02-11, 03:18 PM
