Thread: Purge a table
    2009-11
    Raleigh, NC
    941
    Default Purge a table
    I have broken down a file to its bare minimal except one item. Its a table style called "Legend" and there is a text style called legend associated.
    The purge of non purgable items is as shown in image.
    This table style is not current and the fonts in the table style have been changed to Standard and the dwg saved.
    How can I find this "DisplayMap1"
    Turlock, CA
    6,409
    2
    Default Re: Purge a table
    QSELECT is your friend.
    C:> ED WORKING....
    LinkedIn
    Turlock, CA
    6,409
    2
    I just discovered something new. If you doubleclick on DisplayMap1 within the purge dialog, it should select the entity for you and zoom to the selection.
    C:> ED WORKING....
    LinkedIn
  1. Purge till you can purge no more
    By gfreddog in forum AutoLISP
    Last Post: 2018-11-28, 02:09 PM
  2. Purge: The existing purge command misses some stuff that could be purged from a file.
    Last Post: 2010-03-12, 12:28 PM
  3. Purge a layer without purge command
    By cadconcepts in forum AutoLISP
    Last Post: 2007-09-24, 06:11 PM
  4. What's the difference between "purge" and "-purge"?
    By danielmiller19929945 in forum AutoCAD General
    Last Post: 2007-03-08, 05:45 PM
  5. Replies: 6
    Last Post: 2006-08-16, 07:55 AM
