Thread: numeric command aliases
    Wish List Administration
    2011-08
    4,581
    Default Re: numeric command aliases
    Summary: make numeric command aliases possible for existing commands and for new commands
    Description: column 1 = ## numeric aliases
    column 2 = commands, existing
    and
    column 1 can be linked to AutoLISP routines
    drag and drop would be very nice, if possible
    example
    hi There. I am right handed but use a right-handed mouse as Left-handed, with no change
    I figured out to defun C) command save etc. I now have 100's of FREE numeric LISP routines
    for basic everyday use, mostly Layers, but You can write whatever You want for any cad use.
    example,
    (defun c:0/ () (command ".layer" "t" "0" "on" "0" "s" "0" "") (princ))
    (defun c:014 () (command ".layer" "t" "0" "on" "0" "s" "0" "on" "*" "") (princ))
    (defun c:/ () (command "laymcur") (princ))
    (defun c:// () (command "laycur") (princ))
    (defun c:/// () (progn (load "mat-mtc") (c:mtc)) (princ))
    ;(defun c:/+ () (c:laylck) (princ))
    (defun c:/+* () (command ".layer" "lock" "*" "") (princ))
    (defun c:/+- () (command ".layer" "lock" "*" "unlock" (getvar "clayer") "") (princ))
    ;(defun c:/- () (c:layulk) (princ))
    (defun c:/+/ () (progn (setq ssg (entsel)) (setq ssg (cdr (assoc 8 (entget (car ssg)))))
    (command ".layer" "s" ssg "lo" "*" "un" ssg "") (princ)))
    (defun c:/-/ () (progn (setq ssg (entsel)) (setq ssg (cdr (assoc 8 (entget (car ssg)))))
    (command ".layer" "s" ssg "lo" ssg "un" "*" "") (princ)))
    (defun c:/-* () (command ".layer" "unlock" "*" "") (princ))
    (defun c:/0+ () (command ".layer" "lock" "0" "") (princ))
    (defun c:/0- () (command ".layer" "unlock" "0" "") (princ))
    (defun c:/0+* () (command ".layer" "lock" "0-*" "") (princ))
    (defun c:/0-* () (command ".layer" "unlock" "0-*" "") (princ))
    (defun c:/+0 () (command ".layer" "lock" "~0-*" "") (princ))
    (defun c:/-0 () (command ".layer" "unlock" "~0-*" "") (princ))
    (defun c:/* () (c:laymch) (princ))
    (defun c:/** () (command "_matchprop") (princ))
    other,
    (defun c:/*- () (command "options" "") (princ))
    (defun c:0 () (command "orthomode" 0) (princ))
    (defun c:1 () (command "orthomode" 1) (princ))
    (defun c:2 () (progn (command "cmdecho" 1) (command "dist") (getvar "distance")))
    (defun c:3 () (progn (command "cmdecho" 1) (command "dist" "nea" pause "per" pause) (getvar "distance")))
    (defun c:4 () (command ".osnap") (princ))
    (defun c:5 () (command "'osnap" "") (princ))
    (defun c:6 () (command "'osnap" "end,ins,int,mid,per") (princ))
    (defun c:7 () (command "'osnap" "nea,per") (princ))
    (defun c:7+ () (command "'osnap" "nea,end") (princ))
    (defun c:8 () (command "'osnap" "ins,cen") (princ))
    (defun c:9 () (command "'osnap" "ins,cen,quad") (princ))
    (defun c:00 () (progn (command nil nil nil)(command ".save" "") (princ)))
    (defun c:01 () (progn (load "lyr-lno") (c:lno)) (princ))
    (defun c:02 () (command ".qsave") (princ))
    (defun c:03 () (progn (prompt "\nwblocking to file: ") (command ".wblock" "~") (princ)))
    (defun c:04+* () (command ".xref" "r" "*"))
    (defun c:04-1 () (command ".xref" "r" pause ""))
    (defun c:04-* () (command ".xref" "u" "*"))
    (defun c:05 () (command ".xclip" pause "" "s") (princ))
    (defun c:05-1 () (command ".xclip" pause "" "n" "y" "s") (princ))
    (defun c:06 () (c:re) (princ))
    (defun c:07 () (command ".regen") (princ))
    (defun c:08 () (command ".regenall") (princ))
    (defun c:09 () (command ".redraw") (princ))
    (defun c:10 () (command "'pan") (princ))
    (defun c:11 () (command ".zoom" "w") (princ))
    (defun c:12 () (command ".zoom" ".95x") (princ))
    (defun c:13 () (command ".zoom" ".5x") (princ))
    (defun c:14 () (command "'zoom" "p") (princ))
    (defun c:15 () (command "'zoom" "d") (princ))
    (defun c:16 () (command ".zoom" "e") (princ))
    (defun c:17 () (command ".zoom" "e" "zoom" ".98x" ".save" "") (princ))
    (defun c:18 () (progn (load "vue-vsx") (c:vsx)) (princ))
    (defun c:18 () (command "view" "s" pause) (princ))
    (defun c:19 () (progn (load "vue-vrx") (c:vrx)) (princ))
    (defun c:19 () (command "view" "r" ) (princ))
    (defun c:20 () (command ".arc") (princ))
    (defun c:21 () (command ".line") (princ))
    (defun c:22 () (command ".pline") (princ))
    (defun c:22-1 () (command ".pline" pause pause "a" "s" pause pause "l" pause "c") (princ))
    (defun c:22-2 () (command ".pline" pause pause "a" "s" pause pause "s" pause pause "s" pause pause "l" pause "c") (princ))
    (defun c:23 () (command "rectang") (princ))
    (defun c:24 () (command ".polygon") (princ))
    (defun c:25 () (command ".insert") (princ))
    (defun c:25+ () (command ".insert" "~") (princ))
    (defun c:25+0 () (command ".insert" "~" "0,0,0" "" "" "") (princ))
    ;(defun c:25-0 () (progn (load "blk-blk0") (c:blk0)) (princ))
    ;(defun c:25-1 () (progn (load "blk-blk1") (c:blk1)) (princ))
    ;(defun c:25-4 () (progn (load "blk-blkx") (c:ble)) (princ))
    ;(defun c:25-5 () (progn (load "blk-blkx") (c:blkx)) (princ))
    (defun c:26 () (command ".circle") (princ))
    (defun c:26-3 () (progn (setq dsmm (getreal "\nEnter Distance in MM for Circle Radius: ")) (command ".circle" pause (/ dsmm 25.4))) (princ))
    (defun c:27 () (progn (load "n27") (c:n27)) (princ))
    (defun c:28 () (command "block") (princ))
    (defun c:28/ () (progn (setq blkn (getint "\nEnter Int for Blk-Name: ")) (setq pt0 (getpoint "\nEnter Blk-Base Pt0: "))
    (setq ssbn (ssget))
    (command ".block" blkn pt0 ssbn "")(command ".wblock" blkn "=" ) (command ".oops")) (princ))
    (defun c:28/0 () (progn (setq blkn (getint "\nEnter Int for Blk-Name: ")) (setq pt0 "0,0,0") (setq ssbn (ssget))
    (defun c:28+ () (command "wblock") (princ))
    (defun c:29 () (command ".bhatch") (princ))
    (defun c:30 () (command ".erase") (princ))
    (defun c:30-1 () (command ".erase" "L" "")(princ))
    (defun c:30-2 () (command ".erase" "P" "")(princ))
    (defun c:31 () (command ".move") (princ))
    (defun c:31-1 () (command ".move" "L" "") (princ))
    (defun c:31-2 () (command ".move" "P" "") (princ))
    (defun c:32 () (command ".copy") (princ))
    (defun c:32-0 () (command ".copy" "m") (princ))
    (defun c:32-1 () (command ".copy" "L" "") (princ))
    (defun c:32-2 () (command ".copy" "P" "") (princ))
    (defun c:33 () (command ".offset") (princ))
    (defun c:33-1 () (command ".offset" pause "L" "") (princ))
    (defun c:33-12() (progn (setq ds12 (getreal "\nEnter Distance in FT to Offset: ")) (command ".offset" (* ds12 12))) (princ))
    (defun c:33012() (progn (setq ds12 (getreal "\nEnter Distance in FT to Offset: ")) (command ".offset" (* ds12 12))) (princ))
    (defun c:33-3 () (progn (setq dsmm (getreal "\nEnter Distance in MM to Offset: ")) (command ".offset" (/ dsmm 25.4))) (princ))
    (defun c:33-4 () (progn (setq dsm (* (getdist) 25.4)) (princ dsm)) (princ))
    (defun c:34 () (command ".trim") (princ))
    (defun c:34-0 () (command ".trim" (ssget) "" "0,0" "12000,0" pause))
    (defun c:34-1 () (command ".trim" (ssget) "" "0,0" "0,12000" pause))
    (defun c:34-2 () (command ".trim" (ssget) "" "f" pause))
    (defun c:35 () (command ".extend" pause "" pause "" (princ)))
    (defun c:35-2 () (command ".extend" pause "" "f" pause pause))
    (defun c:36 () (progn (command ".fillet" "r" "0") (command ".fillet")) (princ))
    (defun c:37 () (command ".fillet" "r" pause) (princ))
    (defun c:38 () (command ".mirror") (princ))
    (defun c:38-0 () (command ".mirror" (ssget) "" "0,0" "12000,0" "N"))
    (defun c:38-1 () (command ".mirror" (ssget) "" "0,0" "0,12000" "N"))
    (defun c:38-11() (command ".mirror" "L" "" pause pause "N"))
    (defun c:38-12() (command ".mirror" "L" "" pause pause "Y"))
    (defun c:38-21() (command ".mirror" "P" "" pause pause "N"))
    (defun c:38-22() (command ".mirror" "P" "" pause pause "Y"))
    (defun c:38-9 () (command ".mirror" pause "" pause pause "Y"))
    (defun c:39 () (command ".stretch") (princ))
    (defun c:40 () (command ".rotate") (princ))
    Product and Feature: AutoCAD - DWG
    Submitted By: randy.sanders802717 on 01/10/2023
    Turlock, CA
    6,420
    I appreciate your desire to share what you have learned, but that's what the forums are for. This is an abuse of the wish list system.
    C:> ED WORKING....
    LinkedIn
    2005-06
    in the upper right corner
    3,508
    Yes and also, most of this can be achieved with modifying the PGP file and other means like macros you create right out of the box, so it already exists in one form or another.
