Thread: Import Sheet brought Dwg links
    2014-05
    3
    Default Import Sheet brought Dwg links
    I have a user at my company that is working on a large project with multiple buildings. Each building is its own Revit model. They tried to "Insert Views from File" to bring in a detail sheet that only has drafting views on it. After the import completed, they tried to synch. At that time they got a warning that there were multiple dwg links with the same name. It seems importing the sheet, with only line work in the drafting views, also brought some of the dwg links.
    The duplicate dwg's would show under "Manage Links" but they could not locate them in the actual model anywhere. They ended up having to close the file without synching because Revit would not allow a synch with this error.
    Further investigation allows them to copy/paste the individual views without error but needing to re-layout the sheet.
    Does anyone what could have caused this? Or why a sheet would bring linked dwgs with unrelated drafting views?
    Any help on this would be appreciated since we will need to use these details on multiple buildings and it would be tedious to have to recreate the sheet.
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    426
    Default Re: Import Sheet brought Dwg links
    Revit does not respect the Overlay setting for xrefs in ACAD ... if another DWG is referenced into the one you are linking to Revit, it will come along.
    2014-05
    3
    It appears the details from the original file had been copied from a much older file that had CAD links used as detail components. Copying the detail alone would replace the CAD Link. Copying the sheet would duplicate it.
    The details are now being updated to only be detail components.
  1. Linetypes (custom) brought in from designcenter
    By dbanker in forum AutoCAD General
    Last Post: 2007-07-20, 04:58 PM
  2. Can an AutoCAD Mechnical 2006 toolbar be brought into AutoCAD
    By gemco in forum AutoCAD Mechanical - General
    Last Post: 2007-01-24, 09:25 PM
