Thread: 8' Diameter manhole
    Raleigh, NC
    944
    Default 8' Diameter manhole
    Why does a 96" interior diameter manhole reduced the to scale 8' interior diameter block to 6.7' when using the Size option "Use fixed scale from part size" of the default 96" diameter from the default catalog?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: 8' Diameter manhole
    Are you referring to the interior circle? As you are using a block, the block is scaled to fit the part's exterior size. The entities within your block are thus scaled proportionately to the exterior size. The block elements within are not adjusted to match the wall thickness, nor the interior diameter.
    You would need to create a block with the interior wall diameter to match your part parameters.
  1. Civil - Manhole
    By awill81226338 in forum Dynamic Blocks - Sharing
    Last Post: 2009-04-08, 06:21 PM
  2. Civil -Profile manhole, pipe, elipse and text leader
    By NEaton in forum Dynamic Blocks - Sharing
    Last Post: 2008-01-09, 12:27 PM
  3. Civil - Sanitary Manhole Profile
    By Mlabell in forum Dynamic Blocks - Sharing
    Last Post: 2007-03-06, 09:19 PM
  4. Civil - Dynamic Manhole
    Last Post: 2007-02-18, 05:35 PM
  5. Pre-set Manhole Sump
    By gmatheson.88942 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2007-01-26, 04:24 PM
