Results 1 to 10 of 13
Thread: automatically drawn centerlines
    2006-11
    Martinsburg, WV USA
    199
    Default automatically drawn centerlines
    Is there a way to write a program so that it will find all of the 4-sided polylines on a particular layer, and draw a centerline parallel with the long sides of the polylines? there would potentially be hundreds of closed polylines to draw centerlines on.
    I have an example file I am trying to upload, but it keeps telling me it exceeds my limit. It's only 53kb, and I don't know how to delete the old files I've had in the forum from years ago.
    centerline.dwg
    EDIT: Example file attached.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,025
    Default Re: automatically drawn centerlines
    Create a new drawing, draw your example before and after, wblock that to a new drawing. You may need to place the new drawing into a compressed folder. You shouldn't but you might. Upload the zip file.
    2006-11
    Martinsburg, WV USA
    199
    When I go to upload, it says I am using 12.28MB of my 10MB limit. They are all old files from other threads, many years old. I just can not see any option to delete the old files and clear up some room.
    I tried compressing the file, and it still gives me the same message.
    2005-06
    in the upper right corner
    3,478
    Quote Originally Posted by james.126519 View Post
    You can go in and delete old attachments in the "Forum Actions""My Settings" tab above the page
    2006-11
    Martinsburg, WV USA
    199
    Thank you! I updated the original post with the example file.
    2010-06
    962
    Hi,
    You did not show the where you would like to locate the centerline on 4 sides polylines in your drawing. !
    Will it be on the two longest segments center point or in the center of rectangle ?
    2006-11
    Martinsburg, WV USA
    199
    Quote Originally Posted by Tharwat View Post
    Hi,
    The red lines on the layer EPCENTER are the lines I would want added to the drawing. The drawing would already have the yellow polylines created. The centerlines would have to be lines on the EPCENTER layer.
    2010-06
    962
    Hopefully this is the one you are after.
    (defun c:Test (/ int sel ent pts pt1 pt2 pt3 pt4 sg1 sg2 1pt 2pt )
      ;;	Author : Tharwat Al Choufi			;;
      ;; website: https://autolispprograms.wordpress.com	;;
      (and (princ "\nSelect closed polylines to draw centerline on longest segment : ")
           (setq int -1 sel (ssget '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&=") (70 . 1))))
           (while (setq int (1+ int) ent (ssname sel int))
             (foreach itm (entget ent)
               (and (= (car itm) 10)
                    (setq pts (cons (cdr itm) pts))
             (mapcar 'set '(pt1 pt2 pt3 pt4) pts)
             (and (equal (distance pt1 pt3) (distance pt2 pt4) 1e-2)
                  (or (and (> (setq sg1 (distance pt1 pt2)) (setq sg2 (distance pt2 pt3)))
                           (setq 1pt (polar pt2 (angle pt2 pt3) (/ sg2 2.0))
                                 2pt (polar pt1 (angle pt1 pt4) (/ sg2 2.0))
                      (setq 1pt (polar pt1 (angle pt1 pt2) (/ sg1 2.0))
                            2pt (polar pt3 (angle pt3 pt4) (/ sg1 2.0))
                  (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(90 . 2) '(70 . 0)
                                 '(8 . "EPCENTER") (cons 10 1pt) (cons 10 2pt))))
             (setq pts nil)
      (princ)
    2006-11
    Martinsburg, WV USA
    199
             (setq pts nil)
      (princ)
    I don't know what you drink, but I owe you one!
    2010-06
    962
    Its my secret so you can donate me one from HERE if you like.
  1. I want to relinquish things automatically just as I own things automatically
    Last Post: 2012-06-25, 06:44 PM
  2. Russian standart (GOST) want elbow centerlines made as centerlines
    Last Post: 2012-01-13, 01:21 PM
  3. Replies: 0
    Last Post: 2009-05-01, 03:25 PM
  4. Replies: 4
    Last Post: 2008-04-30, 03:35 PM
  5. Window Centerlines
    By philipnoland in forum Revit Architecture - General
    Last Post: 2005-10-14, 11:44 PM
