Thread: File Owner
    2023-01
    38
    Default File Owner
    Good morning.
    I have a file that says it is locked by owner. How can I find out who the owner of the file is?
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Default Re: File Owner
    In File Explorer, browse to the folder the file lives in and open the ".dwl" ... the username with the file open will be the first line and the computer used is the second line.
    2015-10
    442
    The alert I get also shows the user & computer that has the file open:
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    2
    The WhoHas command and then select the file will tell you the same information.
  1. Owner/Architecure/Sub Contractors... etc. behaviour/practices
    By DoTheBIM in forum Revit Architecture - General
    Last Post: 2009-09-02, 03:57 PM
  2. "invalid owner object" Error
    By david.brissenden in forum VBA/COM Interop
    Last Post: 2008-11-28, 11:26 AM
  3. Model to CM & Owner For Training
    By lhanyok in forum Revit Architecture - General
    Last Post: 2008-02-28, 05:01 AM
  4. need to get owner-provided CAD drawings on our sheets
    Last Post: 2006-08-29, 08:52 PM
  5. Changing name of workset owner
    By Henry D in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2004-01-25, 12:28 PM
