Thread: How do I turn on Point Labels for Points that were imported into a surface
    2012-09
    35
    Question How do I turn on Point Labels for Points that were imported into a surface
    I have a 3rd party program/plugin (PVCad) that creates a .csv point file that I need to import into Civil3D and create a surface from.
    I end up with a .csv file that has 3,000+ points in it.
    If I click Insert > Points from File, It takes 1 hour or more to import the points. But then I can create my surface from them and display them how I want.
    If I create a surface and then add a point file to the definition of that surface, it imports the points in seconds, however I can't figure out how to turn on the point labels to display the elevations at those points. I can only display the point marker?
    Thanks!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: How do I turn on Point Labels for Points that were imported into a surface
    You don't.
    The first method is creating actual COGO points. The second method is just adding the point data to the surface without importing the points as COGO points.
    2012-09
    35
    You don't.
    I was afraid that would be the case.
    Are there any best practices for streamlining the import of 3,000 - 10,000 cogo points from a .csv ?
    2002-01
    jUSt Here (a lot)
    9,103
    I don't work with COGO points enough and especially in those quantities to provide a best practices. I do know my firm uses the Survey Database, but I don't know if that would help your situation.
    Do the points you are wanting to import contain feature codes? If not, the current method of attaching the csv to the surface may be the proper workflow.
    2012-09
    35
    No feature codes, just ENZ or XYZ columns. Unfortunately I need to display the Z values, so attaching the csv to the surface isn't getting me there.
  1. CV104-1P: One Point, Two Point, Red Point, Blue Point
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-05-05, 03:17 AM
  2. CV12-4: One Point, Two Point, Red Point, Blue Point
    Last Post: 2013-04-17, 04:50 AM
  3. How to delete imported objects that were hidden
    By thalim in forum Revit Architecture - General
    Last Post: 2012-08-16, 03:45 AM
  4. I wish there were a shortcut command to turn on and off the display of underlays
    Last Post: 2010-03-12, 06:03 AM
  5. Appearance of Points & Point Labels
    By drafting.33933 in forum AutoCAD Civil 3D - General
    Last Post: 2010-03-11, 02:40 PM
Tags for this Thread
