Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Two Installations w/ OOTB ACAD.CUI - Basics on How Duplicate Mods of First to Second
  1. #11
    Tallahassee, FL USA
    3,651
    Default Re: Two Installations w/ OOTB ACAD.CUI - Basics on How Duplicate Mods of First to Second
    One easy way:
    1. On 2022, Start Menu>AutoCAD 2022>Export AutoCAD 2022 Settings. Saves all customizations to a zip file. Note the path you saved it to.
    2. On 2023, Start Menu>AutoCAD 2023>Import AutoCAD 2023 Settings. Browse to the zip file you saved in step 1.
    Our IT only installed Map 3D, Civil 3D, etc… but not AutoCAD 2023 and none of the options listed at https://knowledge.autodesk.com/suppo...-AutoCAD.html? are on our PC's. I guess AutoCAD must be installed as well to have those options.
  2. #12
    6,374
    Maybe it's a Map thing? I have it for acade and amep. I noticed on this page that there is adMigrator.exe.
    Alternative 2: Migration using Windows shell (for advanced users only)
    The migration utility is called AdMigrator.exe and is in the AutoCAD program folder. For example:
    C:\Program Files\Autodesk\AutoCAD 20xx\AdMigrator.exe
    Note:
    For the versions of AutoCAD that do not have "Migrate From a Previous Release," double-click the AdMigrator.exe utility to see if it will allow settings to migrate.
    It is probably necessary to designate a specific target for the utility by creating a shortcut. To do this:
    Right-click-drag AdMigrator.exe to the desktop (or other usable folder) and choose "Create shortcuts here."
    Right-click the shortcut and choose Properties.
    At the end of the contents of the Target field, type in a /product parameter:
    AutoCAD Electrical = /product "ACADE"
    AutoCAD Mechanical = /product "ACADM"
    AutoCAD Plant 3D = /product "PLNT3D"
    AutoCAD Map 3D = /product "MAP"
    AutoCAD Civil 3D = /product "C3D"
    Other parameters:
    "s" = silent mode
    "i" = import
    "e" = export
    "file" = the zipped configuraton file, structure: <path>\<name>.zip
    "language" = for example "de-DE" or "en-ENU"
    The entire Target field should read as follows, including quotes, using AutoCAD Electrical 2020, German version, for example:
    "C:\Program Files\Autodesk\AutoCAD 2020\AdMigrator.exe" /product "ACADE" /e /file "C:\temp\Standard_Profil.zip" /language "de-DE"
  3. #13
    I could stop if I wanted to CEHill's Avatar
    2006-05
    TN
    327
    This technique worked for me in this instance: Very nice!
    Only a superficial scrape was experienced: A bandage in the form of add-in installation brought things up to "100% operational health":
    Add-ins present on the original installation require installing on the second installation which does make sense.
    My thanks go to our generous and savvy community colleagues here provide some great insights and practical alternatives should this not work.
    Yours,
    Clint
    Hill
    CAD Systems Operation and Management
    Chemical Plant Process + Mechanical Design Focus Areas
  1. Basics Help (if someone has a second)
    By wjf02006247426 in forum Revit - API
    Last Post: 2011-11-20, 09:21 AM
  2. Replies: 4
    Last Post: 2006-10-25, 12:27 AM
  3. Revit : Installations electrique
    By goutig.112492 in forum Revit Architecture - General
    Last Post: 2006-06-07, 08:16 AM
  4. Globally set-up standard information across AutoCAD installations
    By jgreen.70626 in forum AutoCAD Customization
    Last Post: 2005-04-26, 08:12 PM
