Results 1 to 10 of 13
Thread: Two Installations w/ OOTB ACAD.CUI - Basics on How Duplicate Mods of First to Second
    I could stop if I wanted to CEHill's Avatar
    2006-05
    TN
    327
    Question Two Installations w/ OOTB ACAD.CUI - Basics on How Duplicate Mods of First to Second
    With 2023 AutoCAD, a needed refresher on CUIX file strategies ensues. Along with my custom-named user profile and workspace (brought forward from 2022 via Autodesk's nice migration tools), the custom setup so easily assigned on "computer 1" was not available on "computer 2".
    My current mastery of CUIX manipulation is lacking and required subject matter study (re)starts.
    1. Pointers to subject materials are appreciated.
    2. Your comments are worth their weight in gold bullion.
    BOTTOM LINE
    To have AutoCAD "Vanilla" 2023 installations on both computers 1 and 2 look and operate identically.
    Thanks,
    Clint
    6,300
    4
    Default Re: Two Installations w/ OOTB ACAD.CUI - Basics on How Duplicate Mods of First to Second
    One easy way:
    1. On 2022, Start Menu>AutoCAD 2022>Export AutoCAD 2022 Settings. Saves all customizations to a zip file. Note the path you saved it to.
    2. On 2023, Start Menu>AutoCAD 2023>Import AutoCAD 2023 Settings. Browse to the zip file you saved in step 1.
    Tallahassee, FL USA
    3,646
    One easy way:
    Our IT only installed Map 3D, Civil 3D, etc… but not AutoCAD 2023 and none of the options listed at https://knowledge.autodesk.com/suppo...-AutoCAD.html? are on our PC's. I guess AutoCAD must be installed as well to have those options.
    6,300
    Maybe it's a Map thing? I have it for acade and amep. I noticed on this page that there is adMigrator.exe.
    Alternative 2: Migration using Windows shell (for advanced users only)
    The migration utility is called AdMigrator.exe and is in the AutoCAD program folder. For example:
    C:\Program Files\Autodesk\AutoCAD 20xx\AdMigrator.exe
    Note:
    For the versions of AutoCAD that do not have "Migrate From a Previous Release," double-click the AdMigrator.exe utility to see if it will allow settings to migrate.
    It is probably necessary to designate a specific target for the utility by creating a shortcut. To do this:
    Right-click-drag AdMigrator.exe to the desktop (or other usable folder) and choose "Create shortcuts here."
    Right-click the shortcut and choose Properties.
    At the end of the contents of the Target field, type in a /product parameter:
    AutoCAD Electrical = /product "ACADE"
    AutoCAD Mechanical = /product "ACADM"
    AutoCAD Plant 3D = /product "PLNT3D"
    AutoCAD Map 3D = /product "MAP"
    AutoCAD Civil 3D = /product "C3D"
    Other parameters:
    "s" = silent mode
    "i" = import
    "e" = export
    "file" = the zipped configuraton file, structure: <path>\<name>.zip
    "language" = for example "de-DE" or "en-ENU"
    The entire Target field should read as follows, including quotes, using AutoCAD Electrical 2020, German version, for example:
    "C:\Program Files\Autodesk\AutoCAD 2020\AdMigrator.exe" /product "ACADE" /e /file "C:\temp\Standard_Profil.zip" /language "de-DE"
    2006-05
    TN
    327
    Question Re: Two Installations w/ OOTB ACAD.CUI - Basics on How Duplicate Mods of First to Second
    Hi Ed,
    I will file that important fact!
    For now, 2022 version was uninstalled but not before 2023 "automatically" i.e., without my interaction (exporting/importing) assimilated my 2022 custom workspaces (possibly other components) on my successful 'Computer 1'.
    Now, I must take the rocky path to customize 2023 on "Computer 2".
    Input on customizing by creating a custom CUI may be the best path. What are your thoughts?
    TWO CONCERNS:
    • To maintain consistency between mutliple 2023 installations
    • To futureproof migrations (in case the export/import function fails)
    Yours,
    Clint
    Hill
    CAD Systems Operation and Management
    Chemical Plant Process + Mechanical Design Focus Areas
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,051
    Have you analyzed your modified acad.cui? How different is it from the OOTB acad.cui?
    Of course, the CUI is no longer just a CUI. It is a CUIX, which is just fancy for a compressed folder with actual CUI files inside among other files. The CUI is just an XML file with a different extension.
    You could then extract the CUI from the two CUIX folders and run WinDiff on the two CUI files to see the differences. There may be too many differences to make the check useful, though.
    2006-05
    TN
    327
    AH-HA!
    I will try this very thing sooner than later.
    Thanks Opie!
    Yours,
    Clint
    Hill
    6,300
    To do what Opie is suggesting, make a copy of acad.cuix, change the extension to zip and then extract.
    2006-05
    TN
    327
    Thanks for that important technique without which accomplishing this task would have been a real head scratcher for me!
    Yours,
    Clint
    Hill
    Tallahassee, FL USA
    3,646
  1. Basics Help (if someone has a second)
    By wjf02006247426 in forum Revit - API
    Last Post: 2011-11-20, 09:21 AM
  2. Replies: 4
    Last Post: 2006-10-25, 12:27 AM
  3. Revit : Installations electrique
    By goutig.112492 in forum Revit Architecture - General
    Last Post: 2006-06-07, 08:16 AM
  4. Globally set-up standard information across AutoCAD installations
    By jgreen.70626 in forum AutoCAD Customization
    Last Post: 2005-04-26, 08:12 PM
