Thread: Please help with small lisp modification
    Default Please help with small lisp modification
    The attached lisp selects all closed polylines in a drawing and for each one writes a line in a file (list of coordinates in form Y,X or north,east). I would like to modify it to repeat the first point at the end of each line.
    For example, in a drawing with 2 closed polylines, the output looks like this:
    300,500 300,550 250,550 250,500
    300,700 300,750 250,750 250,700
    end of file
    And I would like it to look like this:
    300,500 300,550 250,550 250,500 300,500
    300,700 300,750 250,750 250,700 300,700
    end of file
    Thank you!
    2003-07
    534
    Default Re: Please help with small lisp modification
    If writing to file why not each point 1 line ? Just use a blank line to seperate.
    Anyway it is making a list of points just add the (last pointinlist) before writing to file.
    (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget plent))))
    (setq co-ord (cons (last co-ord) co-ord))
  1. Hi Helpers, Need a urgent help in small modification of lisp code
    By brahmanandam.thadikonda762224 in forum AutoLISP
    Last Post: 2018-09-28, 04:42 AM
  2. Need a help in modification of lisp. Please update the lisp code as required.
    Last Post: 2018-09-20, 04:12 AM
  3. Modification to a lisp (needs to change the lisp code)
    By nanaji130285733687 in forum AutoLISP
    Last Post: 2016-11-21, 04:45 AM
  4. Small Modification Required, In Existing Lisp
    By prasadcivil in forum AutoLISP
    Last Post: 2016-10-11, 05:45 AM
  5. Replies: 1
    Last Post: 2008-11-04, 05:48 PM
