Thread: AutoLISP for calculating multiple areas, adding text and creating a table
    2023-02
    Default AutoLISP for calculating multiple areas, adding text and creating a table
    Hello,
    I am looking for a LISP routine that would allow me to select multiple closed polylines, calculate their areas and place the areas (in the form of text) inside of the closed polylines. In addition, I need all of the areas placed into a table with the total of all the areas added up.
    Maybe I am asking for too much. Maybe this is a 2-step process. Any suggestions would help!
    Thank in advance
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: AutoLISP for calculating multiple areas, adding text and creating a table
    Have you searched the forums? Also, the similar threads at the bottom of this page provides links to threads the forum software believes are similar. One in particular is the Quick adding of multiple closed polyline areas
    2003-07
    561
    Like Opie so many examples also at Cadtutor & Forums/Autodesk/lisp
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    Lets start with the first part.
    Creating a selection set of closed polylines and getting the areas and totaling them.
    This code returns them as a list.
    P=
    ;___________________________________________________________________________________________________________|
    ; Written By: Peter Jamtgaard copyright 2023 All Rights Reserved
    ; Abstract: This routine allows the user to select closed polylines and return a list of individual areas
    ; and the total area of the selection set.
    ; Comand line function list
    ;* C:PA
    ;* Command Line function to add up areas of selected closed polylines
    ;* C:PolylineAreas
    ; General Function Header List
    ;  Function List Argument1 Argument2 Arguement3
    ;* (PolylineAreas ssSelections)
    ;* Function to convert a selection set of closed polylines to a list of areas with total area
    ;* (SelectionSetToList ssSelections)
    ;* Function to convert a entity based selection set to a list.
    ;$ End Header
    ; Command Line function to add up areas of selected closed polylines
    (defun C:PA ()(C:PolylineAreas))
    (defun C:PolylineAreas (/ ssSelections)
     (if (and (princ "\nSelect Closed Polylines: ")
              (setq ssSelections (ssget (list (cons 0 "polyline")(cons 66 1))))
    ; Function to convert a selection set of closed polylines to a list of areas with total area
    (defun PolylineAreas (ssSelections / lstAreas lstObjects sngArea )
     (if (and (setq lstObjects   (SelectionSetToList ssSelections))
              (setq lstAreas     (mapcar 'vla-get-area lstObjects))
              (setq sngArea      (apply '+ lstAreas))
      (reverse (cons sngArea (reverse lstAreas)))
    ; Function to convert a entity based selection set to a list.
    (defun SelectionSetToList (ssSelections / entSelection intCount lstObjects objSelection )
     (repeat (setq intCount (sslength ssSelections))
      (and (setq intCount (1- intCount))
           (setq entSelection (ssname ssSelections intCount))
           (setq objSelection (vlax-ename->vla-object entSelection))
           (setq lstObjects   (cons objSelection lstObjects))
     lstObjects
    (princ "!")
    (vl-load-com)
    AutomateCAD
    2000-09
    Honolulu HI
    1,109
    This was kinda fun to a ran with it.
    Here is the first routine modified to put area text into the polylines.
    It also groups them.
    You cannot copy the groups.
    You can rerun the program selecting polylines again.
    You can also add the layer you want the "AREA Polylines" To be on.
    P=
    You will have to look at the attachment. The code is too long for 10000 characters
    AutomateCAD
  1. calculating polygons areas using autocad field
    By franciscorefosco in forum AutoCAD Customization
    Last Post: 2017-03-26, 04:57 AM
  2. RAC 2009 - Best Practices for calculating surface areas, etc.
    By designviz in forum Revit Architecture - General
    Last Post: 2009-08-07, 01:56 PM
  3. Quick adding of multiple closed polyline areas
    By CBLENDERMANN in forum AutoLISP
    Last Post: 2008-05-29, 04:21 PM
  4. Areas - Removing Columns from Floor Areas
    By ddavison.33993 in forum Revit Architecture - General
    Last Post: 2006-02-18, 02:39 PM
  5. Calculating Areas
    By johnsonr in forum CAD Management - General
    Last Post: 2004-09-10, 04:19 PM
